01-10-2023, 04:59 PM | #3526 |
Re: What did you do to your truck today.The 3rd chapter
Got my hood on finally
01-10-2023, 06:21 PM | #3527 |
sanded and spray painted the spare wheel, before getting a pizza cutter installed on it this weekend.
Trio 1971 C20 350/700R4 |
01-11-2023, 09:06 PM | #3528 |
I had a new driveshaft made for the 67 . 083 tube x 3.5" spicer joints . One more bite off the elephant .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
01-11-2023, 10:47 PM | #3529 |
Who Changed This?
Changed the oil. I don't remember the last time I did that, but after coming back from our rental house with the oil nice and hot, I finally did it. I don't normally take the truck over there, but I had to have a nice long straightedge to guide the circular saw to trim down a gate. I build things to tight tolerances, and when I built that gate 8 years ago, it was dry and summer. With all this rain, the wood swelled up and the gate was hard to open and close. I'm sure that it has been this way in the past with rain, but the renters never complained. If they had said something, I'd've been all over it. My best complaint about them (after 9 months of not paying rent!)- we had a new toilet put in the rental house, and for whatever reason, the plumber only turned the house water supply valve on part way. Two weeks after that, they were complaining about low water flow. While I will say that the plumber should have opened the valve all the way, they should not have waited two weeks to say something. When I went over to look at the problem, and found it, one of the renters said, "****", because he knew that even he should have seen such a simple problem, having worked for a plumbing company in the past.
01-15-2023, 02:15 PM | #3530 |
Got my door panels painted and put on
01-15-2023, 02:53 PM | #3531 |
Proprietor of Dale's Corner
Looks good
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-15-2023, 03:33 PM | #3532 |
Who Changed This?
Nice! Brought the color right through the door skin!
01-15-2023, 11:16 PM | #3533 |
Nice.
01-16-2023, 02:39 AM | #3534 |
Put a trickle charger on the battery... does that count for anything?
'72 Chevrolet C10- Deluxe/5.7/Short Fleetside '02 Chevrolet Tahoe- LT/5.3/4x4 '13 Ford F150- XLT/5.0/SuperCrew/4X4 '14 Subaru Impreza- Limited/2.0/Sedan/AWD |
01-16-2023, 09:37 PM | #3535 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
I did a rear frame C notch, 4 shocks, greased the front suspension, tracked down a trans leak on my 84 squarebody....all in preparation for the hot rod power tour this year.
01-17-2023, 04:51 PM | #3536 |
Started on my 68 a seat . Ran into a snag the original foam is most likely compressed and the skin is fitting loosely. So I’m going to add some filler to it either poly fit wrap or put jute backing behind the foam . Guess I’ll have a delux or CST seat in a plain Jane .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
01-17-2023, 04:56 PM | #3537 |
Ohh and I had redo a bed board . I moved some stuff and can of paint fell on it putting a big dent in it . I can assure you that I did my best Samual L Jackson “ The hit man’s bodyguard “ imitation .
01-17-2023, 05:32 PM | #3538 |
Blasted and painted my seat frame
01-17-2023, 08:22 PM | #3539 |
I've heard that if you put a damp cloth on top and use your wife's iron it will pull the grain up
01-18-2023, 12:07 PM | #3540 | |
Repair , it slightly altered the grain but you need to look real close
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 01-18-2023 at 01:02 PM. |
01-18-2023, 03:12 PM | #3541 |
Not at all too happy with the seat skin . PUI brand I added the fiber mat which helped with the top and sides fitting tight overall the seat skin is tight ,but no matter how much I stretch the vinyl and heat the puckers won’t come out . If I pull too hard the piping gets distorted around the perimeter . I’m thinking the one side isn’t stitched correctly . Had the same problem with a PUI headliner in my Chevelle . They puckered it at the seam while sowing it .
01-18-2023, 05:15 PM | #3542 |
Made a new spring from a mattress box spring . Seems to work well
01-18-2023, 06:42 PM | #3543 |
Don’t believe this skin is for a 68 full foam even though the box and paperwork say it is . I had to modify it to fit the seat frame . The seat bottom is suppose to clip all around the perimeter was about an inch to long . I had to put a wire in the felt and hog ring it . I got the pleats to line up on one side and the other side is off by about 1/4 of an inch no excuse for that . But it’s together not perfect but it’ll have to do .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 01-18-2023 at 08:21 PM. |
01-20-2023, 08:12 PM | #3544 |
Cement was too cool to lay on, so did some cruising around the area.
01-20-2023, 08:30 PM | #3545 |
Who Changed This?
^ When was Jefferson Davis president?
01-20-2023, 11:26 PM | #3546 |
Civil War, He was the president of the Southern folks.
01-22-2023, 05:21 PM | #3547 |
Did the seat tracks today it’s a pleasure working on parts that aren’t covered in rust .
01-22-2023, 05:26 PM | #3548 |
And somewhere during the process I lost the little clip that holds the spring and wire linkage . So I made a new one out of a left over piece of tool steel from knife making. Lots of hand filing as I didn’t want to overcut it on my belt grinder . Not my favorite thing to do in 90+ degrees . Turned out pretty well
01-22-2023, 05:29 PM | #3549 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
01-22-2023, 07:01 PM | #3550 |
