Old 01-14-2023, 08:58 AM   #1
Lost in the 60's
Active Member
Lost in the 60's's Avatar
WTB 1967 Auto gear shift pointer
It is for a TH400, if that is different...see pic.
Medium blue would be preference
Lost in the 60's is offline   Reply With Quote
Old 01-15-2023, 04:36 AM   #2
pjmoreland
pjmoreland's Avatar
Re: WTB 1967 Auto gear shift pointer
LMC does sell the pointer housing and fiber optic cable (items 9 & 12).
https://www.lmctruck.com/1967-72-che...ing-components
The little L-shaped lens that goes inside the pointer housing, however, is not reproduced for the 67-70 housing. If you already have the L-shaped lens, then it can be transferred to the new pointer housing.
The L-shaped lens is reproduced for the 71-72 housing though, so one option is to go with the entire 71-72 style pointer and indicator setup. This would mean replacing the PRND21 indicator with the 71-72 style as well. It will fit your column.
pjmoreland is offline   Reply With Quote
Old 01-15-2023, 09:45 PM   #3
Lost in the 60's
Active Member
Thanks, I'll wait and see if someone has an original to sell before going to a repro. The lens is in mine and I don't care for the '71 and up indicator housing. Trying to keep this "jewel" as original appearing as possible.
Old 01-15-2023, 11:27 PM   #4
pjmoreland
pjmoreland's Avatar
I prefer the appearance of the 67-70 indicator as well. I looked for a good original for a long time, and only found a couple of broken ones. I think people don't realize they have to be rotated sideways to be removed without breaking the tabs.
NOS pointer housings come up on eBay occasionally. The part number is 3959360. I purchased a couple of them recently. The first one was a dark metallic bronze color, and the other was black (same part number).
I've got this green one that has a small amount of material missing from the sides of the tabs. If you want it, it's yours for the cost of shipping.
Old 01-16-2023, 10:18 AM   #5
Lost in the 60's
Active Member
Wow, absolutely, thank you. I'll pm my address for shipping cost.
Old 01-20-2023, 11:02 PM   #6
Lost in the 60's
Active Member
Got the indicator today, thank you !!
Old 01-21-2023, 01:24 AM   #7
pjmoreland
pjmoreland's Avatar
Glad it made it safely. Hopefully you are able to find one with matching original paint eventually.
Old 01-21-2023, 09:02 AM   #8
Lost in the 60's
Active Member
I still need a glove box door too, so may be doing some painting and "aging" on parts...
