Old 02-19-2023, 06:21 PM   #1
bean
TUBE GRILLE on 72
I know this may be blasphemy... but I m interested In good recommendations for a tube grille for my 72. I need a new outer shell anyway so may as well go all out. Those of have done this where did you get yours from and how was the fit? Thanks guys
bean is offline   Reply With Quote
Old 02-19-2023, 06:30 PM   #2
CG
BlahBlahBlah
Re: TUBE GRILLE on 72
So you are talking replacing the egg crate center section with tubes? I personally really like that look, but have never found a set that I would like. The ones Im talking about are actual tube grills from the 60's and 70's. I have seen billet square tube grills, but not my style so I never looked in to them.
BTW its not blasphemy to build your truck the way you want it =)
Old 02-19-2023, 06:42 PM   #3
72c20customcamper
72c20customcamper's Avatar
Had one on the 72 when I bought it was nice but wasn’t the look I wanted. No idea the brand though
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 02-19-2023, 08:34 PM   #4
best view
Bean there are professionals that can help you with this weird thought
best view is offline   Reply With Quote
Old 02-19-2023, 09:27 PM   #5
dagnabbitt
dagnabbitt's Avatar
I support your idea, although I don't know who makes them now. I'm sure there are vintage ones available that you could restore.
Everything that is old is new again: if you want a tube grill I think it would look good with some cragars etc.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 02-19-2023, 10:27 PM   #6
It's not a weird thought because companies used to make them by the hundreds. Maybe outdated, but was once common. I remember JC Whitney had pages of different car front ends sporting tube grilles
I put one in this Blazer because it was less likely to damage off road, and to be custom. Hey! It was early '80s. Cut me a brake!
The whole way they came about is they are an easy way to create a custom grille. They were super popular back in the good old days when custom meant do it yourself
Old 02-19-2023, 10:30 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ True. In fact, I made a tube grille for my '68 Skylark, many years ago. Certainly cheaper than stock.
~Steven
Simi Valley, CA
Old 02-19-2023, 10:33 PM   #8
Sheepdip
Sheepdip's Avatar
You might want to research that you can actually get your fingers thru the grill to open the hood if you retain the stock latching system, some you cannot.
The PO of my truck had installed one that you first and foremost had to have arms like an orangutan, then lay down on the ground reach up to open it. I cured that within a couple of days. Hey it's a work truck.
Sheepdip is offline   Reply With Quote
Old 02-20-2023, 12:34 AM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yeah, I didn't want to go there. I had to engineer my Skylark's grille to be able to open the hood, as well.
~Steven
Simi Valley, CA
Old 02-20-2023, 08:39 AM   #10
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
After some close inspection of store bought billet grills that are WAY overpriced I decided to make my own. I used a 1/2" stainless steel thin wall tubing, 1-1/2" x 1-1/2" x 16 gauge stainless steel angle. It was quite simple to make actually, the hardest part was getting the center bend angle on all 8 pieces correct. I used 4 sticks of 10' thin wall stainless tubing and one 10' piece of angle. I fastened it in four places with 10-32 stainless screws. If I make another one I'd make the top and bottom tubes slightly longer to fill the contour of the headlight bezels. .23 stainless wire with Argon gas set very low on the welder... PS. Evenly spaced there's enough room to fit your hand to reach the hood latch.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-20-2023, 11:15 AM   #11
I remember Bigfoot had a tube grille. The original owner had put a square tube, wheels, and tires on this '78 Silverado I had. This picture is days after buying it. I ended up putting a '73 grille in it with the 454 badge. It's funny, back before drop spindles lowering was flip kit and cut the front coils. I bought a Rancho kit that called for cutting coils and gave part #s for shorter shocks.
Old 02-20-2023, 09:07 PM   #12
chiefcfd
chiefcfd's Avatar
I bought mine from SOKY Classics. It's been a few years now. Not bad to install. I did put a push bar up to the latch handle accessed below the bumper.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 02-20-2023, 10:41 PM   #13
tutone
tutone's Avatar
My 71 had one . I replaced it first day. It was probably JC Whitney circa 1974. It was a heavily built piece.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71
tutone is offline   Reply With Quote
Old 02-20-2023, 11:01 PM   #14
truckster
truckster's Avatar
It's not a tube grille, but something similar:
https://www.lmctruck.com/1967-72-che...ille-chevrolet
Very pricey, though.
I do think it would be pretty easy to fabricate one, though.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 02-21-2023, 11:35 AM   #15
Rickjz
I created the look using the original grill. Just painted black in between the horizontal parts.
Rickjz is offline   Reply With Quote
Old 02-21-2023, 03:44 PM   #16
cornerstone
cornerstone's Avatar
That's a great way to get that look! Nice work.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 02-21-2023, 10:04 PM   #17
bean
Rickjz that looks great!
Old 02-22-2023, 12:07 PM   #18
LockDoc
The Older Generation
LockDoc's Avatar
Mine isn't a tube, but to overcome the latch problem it has a piece of threaded rod double nutted into the latch handle and it extends down just past the bottom of the bumper. It actually works very well. Your hood has to open easily and you have to keep all of the moving parts lubed though.
LockDoc
Leon
Old 02-22-2023, 07:47 PM   #19
bean
Where did you get your grille lockdoc?
Old 02-23-2023, 01:08 AM   #20
LockDoc
LockDoc's Avatar
It was already installed in the truck when I got it. I got the truck from member "Kingsolver72" so I will ask him if it was there when he got it or if he installed it.
LMC does carry them as well as a few other suppliers. Just type '72 Chevy Billet Grille into Google
https://www.lmctruck.com/1967-72-che...-for-chevrolet
There are a couple of different ones as far as the number of bars, mine has 19.
LockDoc
Leon
Old 02-23-2023, 02:16 AM   #21
dagnabbitt
dagnabbitt's Avatar
That is a really cool and subtle look, I am surprised I have not seen it done before.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 02-23-2023, 07:51 PM   #22
dmjlambert
dmjlambert's Avatar
What a good idea. I need to make a pair of those for my 1969 truck, since it has the big divider that says Chevrolet and has the turn signals.
