03-01-2023, 03:39 PM | #1 |
Steering column what did I do wrong
1967 automatic non tilt column.
I disassembled it and replaced the upper and lower bearings. Reassembled and everything seemed fine. But, for lack of a better description, the shift tube is not returning. Basically, there is no safety to keep from pulling it out of park. It was working before disassembly. There are not many moving parts to this assembly, but I can't figure out what is wrong. It seems almost impossible. Also, it seems "tight" when moving the shift lever, especially out of park. Any ideas? |
03-01-2023, 04:07 PM | #2 |
Re: Steering column what did I do wrong
Some pics
03-01-2023, 04:17 PM | #3 |
The locknut where the trans linkage fastens to the column could be too tight.
03-01-2023, 07:17 PM | #4 |
This thread should help. Look at the photos of the detent mechanism at the base of the column, I believe that is where your problem is.
http://67-72chevytrucks.com/vboard/s...d.php?t=491049
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-01-2023, 07:55 PM | #5 |
Thanks for the comments. I do have an update to my earlier post.
1) The park lock position has been broken off. I had not noticed that before. I guess I always pulled up to shift. But anyway the "hard to pull into gear" remains. The first gear stop is about all that is left of my detent mechanism. 2) Today I loosened the preload on the lower bearing hoping that was the problem. It was not. |
03-01-2023, 08:48 PM | #6 |
The spring clamp on the bottom can make the shifter movement hard and it is not easy to get it set correctly. I used a clamp and vise grip so I could control the movement of the clamp on mine when I replaced the steering box and rag joint on my Burban.
See link below and scroll to post 849 to see photo of clamps with additional information on the next page I hope this helps. http://67-72chevytrucks.com/vboard/s...698377&page=34
03-01-2023, 10:09 PM | #7 |
The cylindrical piece that mounts at the bottom of the column and houses the lower bearing has some adjustment to it. The screws that attach it to the column pass through a band and some slots that are at an angle. With the screws loose, you can rotate this assembly to either increase or decrease the clearance between the detent plate and the arm that the shift rod connects to. If there is inadequate space between the detent plate and arm, then they could be binding up on each other.
