![]() Join Date: Mar 2003
Re: Axle Ratio Question
All the early front Dana 44 stuff will swap around. So yes you can swap the gears if you want. Putting used gears in the front is not a big deal. Before removing them clean them as best as you can and get a pattern and backlash reading. Match it as close as you can in the different housing and you'll be ok
