03-15-2023, 07:57 PM | #1 |
DBW Accelerator Pedal Options
Trying to figure out the best/cheapest way to get an working accelerator pedal installed in this swap. Using a 2006 6.0/4L80E. I kept the pedal assembly out of the donor but it was an adjustable style and don't want to deal with all that extra bracketry etc. I did see a guy that used a pedal assy out of a 1996-2000 C3500. Says bolts right up and then you just have to swap 2 wires in the interface cable.
Anyone use this pedal in their swap? |
03-15-2023, 09:13 PM | #2 |
Re: DBW Accelerator Pedal Options
The 05+ Corvette pedal looks identical to the 71-72 pedal, even accepts the SS trim. It is bolt in with Hart Rod's bracket. Have this setup in my 72. http://67-72chevytrucks.com/vboard/s...d.php?t=631165
A recent thread on the subject, just a few pages back https://67-72chevytrucks.com/vboard/...d.php?t=840601
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 03-15-2023 at 09:20 PM. |
03-16-2023, 06:23 AM | #3 |
As Richard stated, I used a Corvette pedal. I made the bracket that bolts tot he firewall, but many people make them. I cut the pedal a bit shorter for myself, but I used all the chrome trim from a 72 pedal and it looks/works great.
03-16-2023, 07:35 AM | #4 |
My engine didn't come with the pedal or tac.. so I swapped it to dbc throttle.
The one I'm working on now has all the dbw stuff.. kinda wish I had swapped it to dbc I think what Richard said will do the trick
03-16-2023, 08:57 AM | #5 |
Not sure if it is the same on the 2006, but my 2003 adjustable pedal had a smaller range or motion than the non adjustable of the same year.
I originally got a replacement non adjustable and my pedal sat kind of high. In a quest for maximum leg room, I sliced, diced and welded to get the adjustable pedal as close to the floor as I could when fully depressed. |
03-16-2023, 12:56 PM | #6 |
For some reason the difference between truck and car pedals is two wires have to be swapped positions. When I used a car pedal on my swap (08 truck 5.3 Vortec) I had to swap two wires in the D and F positions at the pedal plug. The WH/BK and the BN ones.
03-16-2023, 07:06 PM | #7 |
A lot of these comments are not going to work on a GenIII engine. With a 2006, you are pretty much stuck with using a 2002-06 pedal. I have heard of people using the diesel pedal you posted a pic of, but others have had problems with it. Never personally tried one myself, so have no firsthand experience with it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-18-2023, 09:17 AM | #8 |
low n' slo
I don't think I've seen the adjustable style. my 2002 pedal mounted to hart robs bracket fit like a champ
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
03-18-2023, 11:40 AM | #9 |
This is what adjustable pedals look like. I think they came with well optioned vehicles. They have a cable driven gear box on them to adjust the height. I've heard of people removing the adjustable part and replacing it with a permanent link of some sort, once they figure correct height.
03-19-2023, 12:41 PM | #10 | |
It is my understanding the the big difference between the 2 setups is that the earlier units use 3 potentiometers in the pedal while the later version only use 2. But from everything I read the first 2 that used are the same in both eras. So when using the earlier pedal with the later TAC module it just ignores the 3rd potentiometer. |
03-20-2023, 11:36 AM | #11 | |
low n' slo
OP, is there a reason you dont want to use the 2002-2006 pedal with the TAC box? seems like the easiest and cheapest option
03-20-2023, 04:33 PM | #12 |
If I go get a non-adjustable pedal (cause I don't want to have to slice and dice my adjustable) 2002-2006 pedal then I have either buy a mounting bracket or figure one out myself. If I have to buy a pedal anyways and I just buy the 2000 C3500 pedal it bolts right into the 69 factory mounting holes and I just have to swap two wires on the harness connector.
03-20-2023, 05:49 PM | #13 | |
03-20-2023, 07:06 PM | #14 |
03-20-2023, 07:22 PM | #15 | |
Posted via Mobile Device |
04-07-2023, 01:44 PM | #16 |
Here's a new video on the the pedal topic. This is the guy that mentioned in an earlier video that that adjustable pedals have shorter travel:
https://www.youtube.com/watch?v=_qO5Jjl6Py0 |
04-09-2023, 10:06 AM | #17 |
The first DBW Corvettes 1999-2001 (The first adapters in the GM line) require their own TAC module. It is expensive and impossible to find. Be sure to avoid that unit.
