Old 03-07-2023, 10:36 AM   #651
Rickysnickers
Re: Yet another GMC build
Very well done!
Old 03-10-2023, 08:39 PM   #652
daveshilling
daveshilling's Avatar
Originally Posted by OKGMC4 View Post
Engine bay assembled
Sweet mother of GOD what is this wizardry?! That's your freaking INTAKE? Leave some ladies for the rest of us man, and don't come near my wife.
daveshilling is offline   Reply With Quote
Old 03-19-2023, 03:08 PM   #653
OKGMC4
OKGMC4's Avatar
First time in the sun for 2 years. Got gas and so far so good. Need to adjust one coil over for height, an alignment, a dyno tune, and charge the AC.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 03-19-2023, 03:48 PM   #654
daveshilling
Big Day!! Excited for you, and excited to do the same thing one day.
Old 03-19-2023, 10:19 PM   #655
dsraven
AND it was sunny, nice. must feel good to start it up and drive it outside in the sun.
Old 03-20-2023, 08:44 AM   #656
6DoF
6DoF's Avatar
that bed box is MONEY!
and congrats on the sunshine!
6DoF is offline   Reply With Quote
Old 03-20-2023, 10:14 AM   #657
Rickysnickers
Awesome job!!!
Old 03-20-2023, 10:21 AM   #658
mongocanfly
mongocanfly's Avatar
Nicely done...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-20-2023, 11:00 AM   #659
oldman3
oldman3's Avatar
Looks great...Jim
oldman3 is offline   Reply With Quote
Old 03-20-2023, 11:15 AM   #660
Kevin_C
looks great!
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 03-23-2023, 07:15 AM   #661
OKGMC4
OKGMC4's Avatar
My rack started leaking from both bellows and I’m not really sure why. It was rebuilt in 2011 but maybe the seals didn’t like sitting so long or maybe it wasn’t a good rebuild to begin with? Unsure. Anyhoo, it looks like C4 racks are getting rare because they are going for $300-$400 on ebay, parts stores can’t get them anymore, Turn One in Michigan can rebuild one but that starts at $375 with a minimum 2 week lead time. I thought I’d try my hand at a $30 seal kit but when I got to reassembly I could not get the short shaft back in without destroying the 4 square nylon rings on it. Believe it will take special tools to do properly. Plus no way to test it first and still don’t know why it failed. I found that a company called Lares in Minnesota produces new c4 racks with a lifetime warranty. Summit has them for $450. I hate to spend that much but might be the best option since used is so much. When it came time to choose between Flatout Engineering or Progressive Automotive for a crossmember I went with the one that fit my corvette rack. Since seeing you can get a tbird rack for $100, wondering if I made the right choice.
Old 04-22-2023, 11:59 AM   #662
OKGMC4
OKGMC4's Avatar
Got about 200 miles before trouble. Slipped in 1st gear once, temps started climbing, then it started shaking, then the converter started grinding. That was all in a 3 mile trip. Wasn’t even getting on it. Snout on the converter chewed up, front seal came out in pieces, front pump loose. Tranny shop said since I pulled it all out of a truck hit HARD in the front, it probably allowed the converter to smack the pump and crack it. He quoted $1500 to rebuild. Looks like I get to learn how to rebuild a 4L80E!
Old 04-23-2023, 12:02 AM   #663
dsraven
these are pretty good manuals.
https://atsgbookstore.com/4l80e_dl/?...QaAtXEEALw_wcB
Old 04-23-2023, 12:08 AM   #664
dsraven
start with a good power wash.
also, before installation, flush out the cooler lines and replace the cooler.all that stuff is stuck in that old cooler. some will put a filter inline but I am not on that side of the fence, personally. I have seen a hydraulic shop flush new lines and then blow a plug down the line with compressed air to clear any solvent from the line and see if the plug comes out clean or if the line needs more flushing. they use what looks like a roll up ear plug.
Old 04-23-2023, 12:11 AM   #665
dsraven
I have also seen a cut away of a previously flushed plate style trans cooler. it still had lots of debris in the plates. a new cooler is cheap insurance.
Old 04-23-2023, 12:19 AM   #666
dsraven
you're gonna be soooo tired of ATF soon.
Old 05-30-2023, 03:55 PM   #667
OKGMC4
OKGMC4's Avatar
Took the trans apart and all the frictions and steels looked perfect so put them back in. The only damage found was a chewed up converter snout, the stator bushing was banged up, and the front seal came out in little pieces. I replaced the bad parts and put it back in and it’s been driving perfect for almost 200 miles now. Not really sure why it blew the front seal out in the first place. The bad news is I’m not 100 percent thrilled with the 5.3 power. Seems to have about what my cammed 6.0 had naturally aspirated. Not bad, but I ain’t scared yet. Thinking of gapping the 6.0 rings and swapping it. More cubes, little more compression, more cam, and more boost should thoroughly scare / thrill me.
Old 07-11-2023, 06:37 AM   #668
OKGMC4
OKGMC4's Avatar
I pulled the heads off the 6.0 and regapped the rings. I changed the Texas Speed 224R out for a mild custom turbo grind from Cam motion. I changed the wastegate springs for 12lbs. Pulled the 5.3 and pushed in the 6.0. The idle needed raised from 650 to 750 and I think I need to lean the idle out a little below 13.6 where the tuner set it. But the power so far is ridiculous. I only pushed it to half throttle and it’s walking sideways while still accelerating and shifting. I believe I finally have the scary power I’ve always wanted. Need to look into wider stickier tires now.
Old 07-12-2023, 08:04 AM   #669
6DoF
6DoF's Avatar
Old 07-18-2023, 12:01 PM   #670
Kevin_C
Looking great! I saw this video the other day and thought of your truck. I was a bit surprised by his current brake and suspension set up.
https://www.youtube.com/watch?v=nf1MItkMMKM
Old 07-18-2023, 04:31 PM   #671
OKGMC4
OKGMC4's Avatar
Man that thing is a beast!
Old 08-08-2023, 01:19 PM   #672
OKGMC4
OKGMC4's Avatar
Really wanted to make sure my tune was safe for the engine so I had it dyno tuned this morning. The verdict…
605 hp
656 ft lbs.
I think it has more than enough power now. My poor 275/40zr18 tires agree. I had backed down to 10lb wastegate springs because I was afraid to lean out up top. I’d rather give up some power than burn it up at 12lbs boost.
Old 08-08-2023, 02:15 PM   #673
6DoF
6DoF's Avatar
haha, yeah, the makings of a tire smoke show
