Gas tank locking ring size
I'm trying to add a return line to my 71 gmc in cab tank. It currently has one outlet tube. Looking at the 72 sending unit, it has a return already built in. Can I just put the 72 sending unit in the 71 tank and have it fit?
The whole reason for this is a possible Holley Sniper upgrade. No vendor specs out the dimensions??? Thanks Jeff |
Re: Gas tank locking ring size
Finally found an old post from GMCPaul that said you can use a 72 on a 71.
Ill just keep the EEC stock setup. Jeff |
Yes, the 72 sending unit will fit fine. If it's in your budget, Holley offers a underbed tank made just for the Sniper system.
72 C10 lwb fleetside -stock 350/350 combo |
not trying to highjack, but what about a 68 tank? my blueprint motor is coming with it.
Tags |
gas tank, return line, vent line |
