Old 03-19-2023, 05:24 PM   #176
TKCR
TKCR's Avatar
Re: My New Truck
Originally Posted by Factory Guy View Post
The ENGINE now runs! Started it on the stand to see if it would run and it did! so now its time to start the transplant.
awesome!
TKCR is online now   Reply With Quote
Old 03-23-2023, 10:56 AM   #177
ShortHaul
ShortHaul's Avatar
Re: My New Truck
Oh heck yeah!! I bet it sounded extra rowdy with no pipes on it!
Speaking of pipes, have you decided what exhaust you’re doing with?
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 03-23-2023, 03:34 PM   #178
Factory Guy
Factory Guy's Avatar
Re: My New Truck
Yep it was WAY LOUD!
I currently have true duals, probably going to keep the Dual turbo Mufflers I already have on it, since its nice an mellow and its in great shape. Probably have to fabricate a small piece on the drivers side to connect the exhaust that is there to the my new LS Manifolds like you have. The passenger side might bolt up!
Factory Guy is offline   Reply With Quote
Old 03-30-2023, 08:07 PM   #179
Factory Guy
Re: My New Truck
Ok since several of you have ask, about the Fuse box, here it is, on my new Engine. It will mount to the back of the ECU box.
Old 04-05-2023, 07:49 PM   #180
Factory Guy
Re: My New Truck
Since several have ask what I am doing for wiring here's what I did. I had Andy (got his name from Brendan at Lt1swap.com) at:
https://lsxharness.com/
rework my factory harness and thin it down.
He also installs this fuse block and Relay Block as part of the deal.
He also wires up the electric fans through the relay block #1 and #2.
Then the wires come back marked with 12+, "Ign on", ground, and etc.
Old 04-09-2023, 08:19 PM   #181
Factory Guy
Re: My New Truck
Pulled the engine and she was really oily, everywhere that wasn't visible, including the transmission leaking out the rear main seal, (no wonder I had so many oil drips underneath the TRUCK!)
It appears somebody pulled the oil pan in the last 5 years to reseal it? as it is super clean and somebody painted the oil pan), so somebody tried to stop the oil leaking issues?? Upon engine removal it was pretty obvious the engine had never been out of the truck.
So I will start on the cleaning process.
The firewall drives me nuts on how unkept it looks (all the black stuff sprayed everywhere). My guess is GM let it leave the factory like this (since we have owned this truck since 1975). I know nobody in our family ever sprayed anything on the firewall.
Old 04-09-2023, 08:23 PM   #182
Factory Guy
Re: My New Truck
It would appear the control arms, on the suspension haven't been cleaned in years!
Old 04-09-2023, 08:34 PM   #183
Factory Guy
Re: My New Truck
This AC box install by GM is looking a little ratty so it will need to be cleaned up as well!
Anybody had any luck getting the black stuff off, around the box? It sort of scraps off, but it appears it will have to be sanded off?
Yes/no?
Old 04-09-2023, 09:08 PM   #184
SCOTI
SCOTI's Avatar
Re: My New Truck
The 'black stuff' is just an undercoating spray GM used on seams & areas where they were trying to seal.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-10-2023, 08:09 PM   #185
evan
evan's Avatar
Re: My New Truck
Yes/no?
I read somewhere that an eraser wheel works on the black seam sealer. I’m hoping that’s true.
Evan B.
evan is offline   Reply With Quote
Old 04-11-2023, 09:17 PM   #186
Factory Guy
Re: My New Truck
We are going to give it a try over the next several days. The black stuff is so old it is falling off as you touch it, but yet enough is still attached, so much so, that it doesn't come off clean.
Old 04-19-2023, 06:14 PM   #187
Factory Guy
Re: My New Truck
The black stuff on the firewall for the most part scrapped off with a putty knife, when done, it was far from being clean, but it was so old and brittle it pretty much just scrapped off, now I have clean up the rest. Added Rust Oleum rusty metal primer to the "seem" that inevitably rusts on these Squares, and any other bit of surface rust, got the Rust Oleum rusty metal primer. The only spot that really had ANY rust was behind the AC box directly above the blend door opening. So I ground out the rust and applied some Rust Oleum rusty metal primer to that area as well. It was really a small spot. So now I will start sanding the rest and prep for paint.
Old 04-19-2023, 06:24 PM   #188
Factory Guy
Re: My New Truck
So I got everything prepped and getting ready to paint. My Friend convinced me to do the lower footwell of the engine compartment too!
Old 04-19-2023, 06:36 PM   #189
TKCR
TKCR's Avatar
Re: My New Truck
That’s going to look good once it’s all done
Old 04-23-2023, 06:34 PM   #190
Factory Guy
Re: My New Truck
Did some HOUSE CLEANING cleaning over the last 4-5 days.
I think it looks a heck of a lot better!
Old 04-23-2023, 06:35 PM   #191
Factory Guy
Re: My New Truck
Before
Old 04-23-2023, 06:36 PM   #192
Factory Guy
Re: My New Truck
Now to start on the AC box!
Old 04-23-2023, 06:36 PM   #193
TKCR
TKCR's Avatar
Re: My New Truck
Wow! It does look better! Great job
Old 04-24-2023, 09:31 AM   #194
Corts60
Just here to tinker
Corts60's Avatar
Re: My New Truck
Beautiful. Nice work!
Old 04-24-2023, 10:52 AM   #195
evan
evan's Avatar
Re: My New Truck
Looking fantastic!
Evan B.
Old 04-24-2023, 08:44 PM   #196
Factory Guy
Re: My New Truck
Thanks everybody for the compliments!
Old 04-27-2023, 11:41 AM   #197
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: My New Truck
ditto what TKCR said!!.. very nice job.. I think that a nice clean firewall and fenders can really set off a engine bay! very nice truck!
rodstored-72 is offline   Reply With Quote
Old 05-11-2023, 03:46 PM   #198
Factory Guy
Re: My New Truck
A few more pictures
Old 05-11-2023, 08:09 PM   #199
TKCR
TKCR's Avatar
Re: My New Truck
Originally Posted by factory guy View Post
a few more pictures
wow!
Old 05-15-2023, 06:01 PM   #200
Factory Guy
Re: My New Truck
The AC box is in, progress is being made ever so slowly...
