Old 07-06-2022, 03:53 PM   #226
Willie Makeit
Willie Makeit's Avatar
Re: Lets see those BUDDY BUCKETS!!!!!!!
Originally Posted by Canuckvetter View Post
I bought NOS clips off eBay. I may have another set at home but I'm 2500 miles away till mid June.
http://67-72chevytrucks.com/vboard/a...1&d=1652328785
would be interested in a set of those clips should you run across another set.
Willie Makeit is offline   Reply With Quote
Old 07-07-2022, 09:21 PM   #227
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by bobvilla67 View Post
Seats are done for my dads truck. Now to install this weekend.
Hot ziggity, those are some nice seats!
~Steven
Simi Valley, CA
Old 02-17-2023, 08:10 AM   #228
C-10 Norway
C-10 Norway's Avatar
Finally got around to re-upholster my buddy buckets last night, just need to clean and paint the slider to consider them done. Added a couple of stainless steel cupholders to the seat back as well.
One question, might be lame, but here goes.
The strap with the velcro, on top of the buddy seat foldable back, what's it's purpose?
Driver carries no cash. He's married.
'67 Chevrolet C10 SWB - 350 Vortec/TH700R4
Backyard Engineering
C-10 Norway is offline   Reply With Quote
Old 02-17-2023, 08:50 AM   #229
Rods
Rods's Avatar
To hold center seat to the cab so it won’t fall forward
Az
Rods is offline   Reply With Quote
Old 02-17-2023, 06:28 PM   #230
C-10 Norway
Thanx for the reply Rods, much appreciated.
Old 02-20-2023, 06:07 PM   #231
YBNORML
YBNORML's Avatar
Basic set, covered in factory parchment. Frame and jump seat powder coated black. Upholstery shop added the cup holders.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-14-2023, 11:20 PM   #232
pjmoreland
pjmoreland's Avatar
I tore apart my buddy bucket seats in preparation for restoring them. Here are a bunch of photos of the internals.
The upper upholstery is stapled closed.
pjmoreland is offline   Reply With Quote
Old 04-14-2023, 11:22 PM   #233
pjmoreland
pjmoreland's Avatar
Mildew!
There is thin foam and plastic sheet on the back side of the upholstery.
Old 04-14-2023, 11:25 PM   #234
pjmoreland
pjmoreland's Avatar
The springs are embedded inside the foam.
Old 04-14-2023, 11:27 PM   #235
pjmoreland
pjmoreland's Avatar
I sure hope I'm able to reuse this rubber U-channel. I'm going to flip it over so the new staples go into a fresh side. The original staple side has some cracks starting to form in it.
Old 04-14-2023, 11:29 PM   #236
pjmoreland
pjmoreland's Avatar
U-channel and staple dimensions
Old 04-14-2023, 11:31 PM   #237
pjmoreland
pjmoreland's Avatar
The bottom flaps of the seat back upholstery overlap and are stapled to the dense rubber U-channel.
Hog ring dimensions.
Old 04-14-2023, 11:33 PM   #238
pjmoreland
pjmoreland's Avatar
There are cardboard stiffeners stapled to sections of the lower upholstery that tuck up under the upper upholstery.
Old 04-14-2023, 11:35 PM   #239
pjmoreland
pjmoreland's Avatar
The seat bottom upholstery is secured with one steel listing wire in the back and hog rings along the sides and front.
Old 04-14-2023, 11:38 PM   #240
pjmoreland
pjmoreland's Avatar
The passenger side foam was in decent condition other than reeking of mildew.
Old 04-14-2023, 11:40 PM   #241
pjmoreland
pjmoreland's Avatar
There is a gridwork of thin steel wires molded into the bottom cushion. It is attached to the lower springs with four pieces of fine rope.
I believe these seats are 1967 model year. The driver seat tilts, and the passenger side is fixed.
Old 04-14-2023, 11:42 PM   #242
pjmoreland
pjmoreland's Avatar
That brown stripe is a rip in the foam that appears to have been repaired in the factory.
Old 04-15-2023, 05:39 PM   #243
zicc1835
zicc1835's Avatar
I just had these recovered when I get to the storage unit ill get a pic of the new covers
zicc1835 is offline   Reply With Quote
Old 04-16-2023, 08:26 PM   #244
zicc1835
zicc1835's Avatar
as discussed here they are recovered
Old 04-23-2023, 01:58 AM   #245
pjmoreland
pjmoreland's Avatar
Here are some photos of the reassembly of my seats. I used spray adhesive to glue the cloth sections of the upholstery to the foam so that it wouldn't be loose.
Old 04-23-2023, 02:00 AM   #246
pjmoreland
pjmoreland's Avatar
I used spray adhesive to secure the foam to the frame.
Old 04-23-2023, 02:02 AM   #247
pjmoreland
pjmoreland's Avatar
I had to add a layer of 1/2" foam to the front surface of the bottom foam because the upholstery was slightly larger than the ACI foam.
The upholstery set was made by Rick's Upholstery.
http://67-72chevytrucks.com/vboard/s...d.php?t=772584
Old 04-23-2023, 07:27 AM   #248
zicc1835
zicc1835's Avatar
Lots of work on those really paid off look grear
Old 04-23-2023, 10:54 AM   #249
pjmoreland
pjmoreland's Avatar
Thank you. Yep, I've put a lot of hours into them. It's been a fun project. I'm planning on assembling the passenger seat this afternoon.
Old 04-23-2023, 11:44 AM   #250
CKfan
Very well documented and a testament to patience. Knowing how much documenting a project takes, your effort is appreciated.
CKfan is offline   Reply With Quote
