Old 05-01-2023, 06:38 PM   #1
bcfishon
New fuel injectors needed , from who?
So my ls swap has been sitting a few years on the shelf and I'm sure the injectors are toast so I want to replace them. The problem I found was the price point is all over the board for stock 5.3 fuel injectors. I can spend up to $800 bucks for eight or a Amazon product for as low as $69. I would prefer to support the local brick and mortar parts store but having a tough time swallowing there price and really just want it done,in short where and what are you payin for your replacement 5.3 stock injectors?.
bcfishon is offline   Reply With Quote
Old 05-01-2023, 08:02 PM   #2
mongocanfly
mongocanfly's Avatar
Re: New fuel injectors needed , from who?
I found the same thing when I was looking at new injectors, pricing all over the map
I used my ultrasonic cleaner and a injector firing tool..cleaned them myself in seafoam...
I read so many bad reviews about the cheap ones .. even ones marked acdelco , heard they were chineseum ones put in gm boxes
if I need to buy any, I'll just pony up and get them from a reliable source..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-01-2023, 08:24 PM   #3
bcfishon
I thought about that but if the price is right I would prefer to replace them.
Old 05-02-2023, 06:35 AM   #4
LeesTruk
Take a look at CS Performance Injectors. I got mine from them, and it didn't break the bank. They'll also provide a flow data sheet showing flow results and you can send them your old injectors for a refund credit.
(cspinjectors.com)
LeesTruk is offline   Reply With Quote
Old 05-03-2023, 06:58 AM   #5
Paul Y
Can I make a suggestion that you look at snakeeater performance
https://www.snakeeaterperformance.com
Brad is a good guy to deal with and his product is stellar.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 05-03-2023, 08:16 AM   #6
biketopia
Stay away from snake eater injectors unless you like melting down your engine, they are cheap and not worth the risk, read on the LS forums and FB about their issues. If your not doing anything crazy with your engine stick with stock ones, sending them off to be cleaned it your best bet, odds are they are fine. What are you using for engine management? If a stock ECU, for simplicity sake stay stock, either another set from the dealer or a reputable parts place, not amazon or eBay if your dead set on replacing them. Or a set from the junk yard or someone parting out a pull out engine.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 05-03-2023, 12:20 PM   #7
Accelo
Accelo's Avatar
A friend of my has a high end turbo motor and almost hydraulic locked his motor because the new Holley injectors leaked out of the box. Then had more issues on the dyno with them.
If you don't need the extra fuel, go stock from a reliable source. Or and easy upgrade is the GM flex fuel injectors. They have some extra capacity and are GM reliable.
Cheers.
Accelo is offline   Reply With Quote
Old 05-03-2023, 12:30 PM   #8
hewittca
hewittca's Avatar
I second the suggestion to have your originals serviced. I recently went through this search process and came to the same conclusions as you have. If you want good injectors at a reasonable price, your most likely option is serviced originals. I ended up building a little test rig and serviced mine with a rebuild kit, but there are plenty of vendors who will service them for you if you don't want to deal with the hassle.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-03-2023, 01:23 PM   #9
biketopia
Cheers.
Good recommendation
Old 05-03-2023, 02:10 PM   #10
mongocanfly
But if you change injectors to a different style, be aware ,not all plugs are the same..
Marc (youngrodder) had his stock Injectors rebuilt, then he hydroed his engine on the 1st crank with them.so be aware..
if for some reason the engine won't turn over, pull the plugs , and dont cause a spark..you may have a cylinder full of fuel
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-03-2023, 04:33 PM   #11
LS short box
On my hot rod LS projects I always send the stock injectors out to cleaned. It's about $300 for a set of eight. They sonic clean them. Check flow rates so they flow all the same and replace the o-rings. Never had an issue. Plug and play.
Per my tuner the off brand injectors aren't "scaled" like the stock injectors and the ECM may run your engine rich or even worse really lean.
Old 05-15-2023, 08:21 PM   #12
bcfishon
I went with CS performance and so far the injectors are working flawlessly, now I also have a set of injectors that I can send in to clean for the next ls swap . thanks for all the suggestions your assistance is greatly appreciated.
Old 06-06-2023, 08:47 PM   #13
72GreenMonster
72GreenMonster's Avatar
Bought the cheapos' from Interweb and ended up having issues out of the gate. Flow tested and cleaned the originals and I have a never had another issue. Lesson learned. Good Luck!
72 GMC Sierra 2500
72GreenMonster is offline   Reply With Quote
Old 06-09-2023, 10:57 PM   #14
bcfishon
The CS injectors are still running great and I have no affiliation with them.
Old 06-10-2023, 09:17 AM   #15
Joyridin
I put Fuel Injector Clinic injectors in my LS3. Their website was a great resource for determining the size I need for the fuel I was running. They are not the cheapest, but you get what you pay for.
Joyridin is offline   Reply With Quote
Old 07-15-2023, 12:39 AM   #16
Squish72
I found brand new pull offs with the fuel rail for pretty cheap on eBay. I got the 55lb gm injectors. Worth looking into
Squish72 is offline   Reply With Quote
