Old 05-09-2023, 10:30 AM   #26
geezer#99
geezer#99's Avatar
Re: Putting miles on 67, 402bbc VS 67 V6 305E
Here’s a mileage kicker for you!
Bought a 70 chevelle ss454 back in 1978. LS6, m22 and 3.08 gear. Previous owner didn’t like the solid lifter cam so he had a stock bb cam installed. Same basic cam as in your 402.
Highway driving at 65 mph it would get 22 mpg. That’s a Canuck gallon. Same as 18 mpg in US gallons. While it sipped fuel it was a real dawg to drive. Ran out of breath at 4500 rpm.
Drove it like that over the winter. In the spring swapped the cam to a LS6 spec but it was a hydraulic cam.
Took care of that gas sipping dawg. Dropped it back to 15 mpg in Canuck gallons. Awesome power difference. Would light em up all the way thru 3rd even with the 3.08 gear.
And now back to your regular programming.
geezer#99 is online now   Reply With Quote
Old 05-09-2023, 10:55 AM   #27
67km1590
Junior Member
Could you call me, five one three, five one eight, three five zero one.
67km1590 is offline   Reply With Quote
Old 05-09-2023, 11:03 AM   #28
1967GMCC20
1967GMCC20's Avatar
Very cool story. 3.08 gears would favor stock low speed, high torque cam. With that gear, you can win "farthest distance awards"... my truck runs great, but needs OD or lower gears. I do like going up hills in drive with 4.10s.
1967GMCC20 is offline   Reply With Quote
Old 05-09-2023, 11:53 AM   #29
Bob B.
Originally Posted by factorystock View Post
When GM started offering the 396-402 in 3/4 tons, a 3.54 Dana became standard equipment, but, if you have the wallet......................
Biggest problem with the V-6 in pickups was GMC usually geared them too low.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 05-09-2023, 07:30 PM   #30
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Originally Posted by RustyPile View Post
Got a 454 in my '71.. It's a disease I tell you. The first symptom is you go around with a smile on your face. Also makes you forget about gas mileage..
No Lie My Brutha! I've always said "if your worried about gas mileage your drivin the wrong truck..."
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-09-2023, 10:55 PM   #31
jimijam00
I think I saw that phone number on a bathroom wall at Playpen Gentleman's Club. The name above the number was Trisha.
jimijam00 is offline   Reply With Quote
Old 05-10-2023, 07:33 AM   #32
1967GMCC20
1967GMCC20's Avatar
My 67 has Patina, but when I open hood with BBC 402, people step back woooo. Is Big Block that big a deal in trucks?
Old 05-10-2023, 01:50 PM   #33
MJN
MJN's Avatar
Originally Posted by 1967GMCC20 View Post
So the rear X member on bell housing is same. Mine is all there. The engine Bell housings were SAE, so I suspect similar.
I chisled the rivits, not torched.
I have the dust shield from Bell housing. Got left behind when I sold engine.
Not to hijack but I have a GMC V6 to SM420 bellhousing. They're not SAE patterns, http://67-72chevytrucks.com/vboard/s...mc+bellhousing
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 05-10-2023, 03:32 PM   #34
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
My 402 just recently came back to life after a 7 yr. hibernation, SWB truck. It's a low mileage rebuild, I only installed new pumps, timing and such since. It runs better than it ever has, I couldn't be happier. It's not quite stock, the heads are 1967 GM HP 396, Delco HEI distributor and high RPM cam.
Differential is a low RPM under-achievement at 3.73:1, there's no burning tires in first gear. On shift it can chirp, that's it. But loves the highway, it just wants to fly. That's what I've always liked about it. No matter how steep a hill it gains speed under little acceleration, and without more.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 05-10-2023, 04:17 PM   #35
1967GMCC20
1967GMCC20's Avatar
Well I got that from 6066. V6 site, they have volumes on the V6. Just checked. Bet it was the larger V6, Larger trucks with 5spd. https://www.smokstak.com/forum/threa...gmc-v6.145198/
I mis read that on the GMC site on design of the engine. V12, large HD truck V6.
Your trans, bolts to my bell housing, same as NP435G (the real 4spd).
Old 05-11-2023, 12:44 PM   #36
jimijam00
A big block with 3.73s should be melting tires. What's wrong with yours?
Old 05-11-2023, 06:08 PM   #37
1967GMCC20
1967GMCC20's Avatar
I have not opened 4 barrel yet, still enjoying cruising.
Kinda wonder how it would run down qtr mile.
Hauled 10ft posts for grapevines today from Farm Store.
Old 05-11-2023, 09:08 PM   #38
71CHEVYSHORTBED402
Couldn't tell you. It's never burned off go, or very little.
Tony
Old 05-11-2023, 09:34 PM   #39
Steeveedee
Who Changed This?
Steeveedee's Avatar
Weird. If I cob mine, even with the shell on it and a 3.56 axle, it'll lay rubber and chirp second. No wheelies like the farm truck, though.
~Steven
Simi Valley, CA
Old 08-02-2023, 11:26 PM   #40
71CHEVYSHORTBED402
Right, and my block sports HP heads off a 67ish 396 SS.
Don't mind me, I don't know what I'm talking about. First off my kick down never worked. Second I had 8" wheels and 70s, so on and so forth, and I probably baby it too much. Everything works now, lots rebuilt, timing chain, trans., axle, carb. etc. I just changed the oil today and figured it's time to really test her out. It runs like a bat out of hell, I'm really surprised. Burns rubber all kinds of ways, but I still refuse to jump from a dead start Too many rocks.
Tony
Old 08-03-2023, 08:17 AM   #41
1967GMCC20
1967GMCC20's Avatar
BBC Keeps running good. Hooking up neutral safety on Lokar shifter today. Thought about that when was going to let someone take it for a spin.
It's amazing how smooth this engine 402bbc runs. Torque is definitely big block.
Old 08-03-2023, 08:20 AM   #42
1967GMCC20
1967GMCC20's Avatar
Next will be adding trailer brake controller so I can pull car hauler.
Old 08-03-2023, 08:47 AM   #43
68panelman
68panelman's Avatar
Show us some pictures of this beast..
68panelman is offline   Reply With Quote
Old 08-03-2023, 02:47 PM   #44
71CHEVYSHORTBED402
I'd like to hear it too
Tony
Old 08-03-2023, 09:30 PM   #45
1967GMCC20
1967GMCC20's Avatar
Have not figured out wonky photo upload process. If it takes more than 3 steps...forget about it.
Old 08-04-2023, 12:04 PM   #46
1967GMCC20
1967GMCC20's Avatar
Can see no pic attachment, what is this the Zuckerberg software?
Old 08-04-2023, 07:18 PM   #47
1967GMCC20
1967GMCC20's Avatar
Just ordered a vintage NOS Kelsey Hayes brake controller fir 67 GMC. Now I can have trailer brakes on the oldie.
Old 08-04-2023, 07:57 PM   #48
1967GMCC20
1967GMCC20's Avatar
Still have NP435G from truck.
Old 08-27-2023, 03:28 PM   #49
1967GMCC20
1967GMCC20's Avatar
Pics
Old 08-27-2023, 03:35 PM   #50
1967GMCC20
1967GMCC20's Avatar
Adding Kelsey Hayes brake controller for pulling trailer.
1967, 305e, 402, gmc
