Old 05-13-2023, 01:57 AM   #1
ghackett1
68 C10 Longbed
ghackett1's Avatar
Are 3927019 the correct sway bar bushings?
For a stock 68 C10 pickup? My front bushings are shot and need replacing.
ghackett1 is offline   Reply With Quote
Old 05-13-2023, 08:19 AM   #2
H A M M
H A M M's Avatar
Re: Are 3927019 the correct sway bar bushings?
My GM catalog says its good back to at least '73, but part interchange on both Napa and O'Reilly show that it is good back to '68.
-Scott
"If it jams, force it. If it breaks, it needed replacing anyways."
Build log coming........eventually.
H A M M is offline   Reply With Quote
Old 05-13-2023, 10:57 AM   #3
ghackett1
68 C10 Longbed
ghackett1's Avatar
Ok copy, thank you.
I’m digging and seem to see a set for .081 and a set for 1.08 so I’m still a bit uncertain.
Old 05-13-2023, 11:54 AM   #4
H A M M
H A M M's Avatar
GM shows them as a 1" ID, 2" high. That part number still comes up in the GM electronic catalog.
-Scott
Old 05-13-2023, 02:14 PM   #5
ghackett1
68 C10 Longbed
ghackett1's Avatar
Thx, yep I ordered an energy suspension urethane set complete with brackets, I got the 1 1/16”, they should be fine and better than the factory rubber.
