Old 12-28-2022, 09:07 PM   #76
zicc1835
zicc1835's Avatar
Re: I am from the Desert
Originally Posted by cornerstone View Post
Glad I checked back in! You've come a long way bud! Your work is spectacular for sure. Is it me or is the forum nearly dead? I would have expected several guys respond to all the work you have accomplished.
thanks for checking back in and the nice compliments ..its been fun and a challenge Im going to have some extra new/ installed /slightly used won't fit my application parts when Im done ill document after I fix and why but for the most part things have gone well .....as far as the nearly dead I think its been so long that I dabble in and out interests and people change ....I think of the build thread as a place to archive and document but its always nice to get a ADAH -BOY I probably look at all the build threads I have subd to and don't respond enough ...well maybe... thanks again im going to try and drive this one by late spring...cause I aint gettin any younger and I have another lady in waiting
jess
zicc1835 is online now   Reply With Quote
Old 01-06-2023, 09:58 PM   #77
zicc1835
zicc1835's Avatar
I converted my cluster to Tach & Clock original gauges were in good shape the kit came from Brothers and I bought a new bezel I should put the spare used parts on the FS forum
Old 01-08-2023, 08:49 PM   #78
zicc1835
zicc1835's Avatar
Delete...............
Old 01-21-2023, 10:37 PM   #79
zicc1835
zicc1835's Avatar
this will work ... push rod for a jeep heated and bent still looking for OEM rods...
Old 02-19-2023, 04:47 PM   #80
zicc1835
zicc1835's Avatar
no real progress my job is getting in the way ......): dash pad done seats back from my guy next week ...its a light saddle picture doesn't do it any justice
Old 03-24-2023, 10:41 AM   #81
cornerstone
cornerstone's Avatar
Any updates to share?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-24-2023, 12:29 PM   #82
zicc1835
zicc1835's Avatar
Brian
Unfortunately I had to work the last 2 weeks of January through first week in march on a assignment just looking at the project when I could get home on the weekends�� I did get the buddies back recovered pictures to follow thanks for asking I’ll get back at it weather is breaking here I see you made some progress��
Old 04-23-2023, 09:02 PM   #83
zicc1835
zicc1835's Avatar
little progress ...should get e brake cable in and cables all hooked up this week powder coated the glove box to try and match the cluster bezel waiting on some textured paint
Old 05-04-2023, 08:58 PM   #84
zicc1835
zicc1835's Avatar
I got me E Brake pedal ready to install and decided to rebuild the kick panel vent door drilled out the rivets media blast powder coated it new gasket replaced rivets with stainless screws and nylocs and installed it real nice tight fit easier than having the E-pedal in the way ....I guess
Old 05-05-2023, 08:22 PM   #85
jaros44sr
jaros44sr's Avatar
Very impressive work my friend, I like the idea of screws
What's next on your project agenda?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-05-2023, 08:47 PM   #86
zicc1835
zicc1835's Avatar
thanks for the kind words Jim... I should have put the eBrake Cables in before I put the cab back on ... now I have to crawl around on the floor to get it done and I will then all new harnesses so I can put the dash back together ..... trying to do a little each day thanks for visiting
Jess
Old 05-06-2023, 09:14 AM   #87
cornerstone
Doing it right as usual! Now I gotta go and look at my vents...
Brian
Old 05-06-2023, 09:26 PM   #88
zicc1835
zicc1835's Avatar
thanks Brian ...if you do do them I have plenty of the gasket material this whole roll... I bought way to much as usual LMK and if anyone else needs I have ..cheap pay for postage
Old 05-06-2023, 09:29 PM   #89
zicc1835
zicc1835's Avatar
Smile Re: I am from the Desert
E Brake cables run peddle installed ...bout time
Old 05-08-2023, 01:27 PM   #90
nicklear36
nicklear36's Avatar
Looks great, love that you kept the cowl vents. Did you have the truck painted or did you do it?
nicklear36 is offline   Reply With Quote
Old 05-08-2023, 08:32 PM   #91
zicc1835
zicc1835's Avatar
thanks for the visit I had it media blasted and epoxy primed inside and out by my blaster
then sent to paint shop ...no more body work or painting for me
Old 05-08-2023, 10:11 PM   #92
cornerstone
Paint work and color look incredible!
Brian
Old 05-09-2023, 07:00 AM   #93
hewittca
hewittca's Avatar
I love this build and your attention to detail. Everything is looking great so far. Keep at it!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-09-2023, 08:41 PM   #94
zicc1835
zicc1835's Avatar
thank you for looking in ...Im trying..to stay at it been busy with the job and I been chasing this beauty Queen and finally captured her. She has distracted me a bit....we went to a local AAC regional show this past weekend and took first in class I wasn't expecting it any way like you ill be back at my first passion weather is improving here and you guys motivate the heck out of me THANK YOU
Old 05-11-2023, 08:04 PM   #95
zicc1835
zicc1835's Avatar
powder coated the edges chrome a few weeks ago used textured paint and advice from a old thread I found so I finished the glove box door not perfect but not bad wanted that textured door to match the cluster
Old 05-11-2023, 11:54 PM   #96
cornerstone
Wow... what a beautiful Pontiac. You nearly have an entire fleet of incredible GM cars at your disposal! Your gonna need a bigger garage.
Brian
Old 05-13-2023, 09:16 PM   #97
zicc1835
zicc1835's Avatar
LOL I have them scattered in neighbors garages
Old 05-13-2023, 09:19 PM   #98
zicc1835
zicc1835's Avatar
started the harnesses today
Old 05-14-2023, 08:02 AM   #99
hewittca
hewittca's Avatar
Nice! What harness did you go with? Everything looks so nice under your dash. I need to get under mine at some point and sort it out as well. It has become a mess during its lifetime.
Old 05-20-2023, 06:19 PM   #100
zicc1835
zicc1835's Avatar
I went with M&H a friend did all new in his 57 corvette and recommended them over painless and others Im pleased lots of labeling and schematics and call if you have issues
