Old 05-24-2023, 09:10 AM   #3826
67C10Step
67C10Step's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by pjmoreland View Post
For the last several months my truck has been making an intermittent noise when idling that sounds like a turkey gobbling. I could only hear it from inside the cab. The exhaust and engine noises were too loud when I'd get out to investigate. I finally discovered that the noise would go away if I applied a little pressure to my shift lever. I applied a little grease to the three contact points between the linkage, transmission and frame mount, and the noise is gone. Now I need to track down the creaking noise that's coming from rear wall of the cab. I sprayed lubricant in a bunch of the seams, but that didn't do it. I think I'll need to take passenger seat out and have my wife drive me around while I crouch on the floor to locate the source of the noise.
I chased a creaky squeak behind the cab in my truck for a while. Thought it was the bed and I practically took the bed off trying to figure it out. Turned out it was the driver's side trailing arm bushing squeaking. Dosed it down with silicone spray a couple times and it went away.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 05-24-2023, 11:25 AM   #3827
pjmoreland
pjmoreland's Avatar
Originally Posted by '68OrangeSunshine View Post
What tranny do you have, Pat?
It's a 4L60 (700R4) out of a 1993 Caprice at Pick-N-Pull. I rebuilt it with the help of an instructional video I purchased from Monster Transmissions. Used a TCI kit. Replaced some of the larger hard parts that are known to be problematic with heavy-duty versions.
pjmoreland is offline   Reply With Quote
Old 05-24-2023, 01:21 PM   #3828
ghackett1
68 C10 Longbed
ghackett1's Avatar
Got the first front end alignment on the 68 today. It’s coming together. Steering wheel nice and straight.
ghackett1 is offline   Reply With Quote
Old 05-24-2023, 01:49 PM   #3829
pjmoreland
pjmoreland's Avatar
Interesting! I will take a look at that.
Old 05-24-2023, 02:02 PM   #3830
Rust_never_sleeps
Rust_never_sleeps's Avatar
got the shorter hoses clocked correctly, and their ends ground down to fit in the brackets. I've been 3h away from bleeding my brakes since Thanksgiving.
THIS TIME FOR SURE!!!!
Rust_never_sleeps is offline   Reply With Quote
Old 05-24-2023, 05:04 PM   #3831
'68OrangeSunshine
'68OrangeSunshine's Avatar
I've heard 700-R4s are tricky. Even more so, a computerized successor in an analog truck.
I have thought about a stoutly-rebuilt TH700-R4 to replace the TH350 in White Fang, my '67 K/10 Suburban, but that's a long way off.
I know you're about one wrench-thru-the-garage-drywall-in-frustration from re-rigging for Manual Transmission. And you're contemplating the T-5 five-speed. I'm not a fan of that unit. A friend had one and we replaced it 3 times one year. In my opinion it's too wimpy in a Truck.
For my money, I'd get a New Process A833 5-speed [or 4+OD]. They were more of a MOPAR tranny, but some mid-'80s Squarebody light duty pickups were optioned with them. The Holy Grail of transmission hunts now.
Old 05-24-2023, 05:11 PM   #3832
pjmoreland
pjmoreland's Avatar
It was a fair amount of work to get the torque converter lockup to work to my liking. I tried various combinations of vacuum switches and time-delay relays, but ended up building an Arduino-based electronic controller for it based on speed and manifold vacuum level. It is documented in this thread:
https://67-72chevytrucks.com/vboard/...d.php?t=822382
Old 05-24-2023, 07:23 PM   #3833
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Took my truck for a wheel alignment today as everything was replaced in the front end. First drive of any distance , just a couple miles to the alignment shop, since te refurbish and what a difference in the way truck drives. Pic is the alignment specs which the tech started going over with me and I told him I'm clueless as to what he's talking about although he said everything was great as far as alignment and suspension went. I'm sure there are folks on here that can relate to the alignment specs.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-25-2023, 02:24 PM   #3834
OregonNed
OregonNed's Avatar
Not today - but visiting a chassis shop tomorrow morning to begin plans on joining those who have lowered their trucks. Going to see what the options are, and to probably include a disc brake upgrade up front.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 05-25-2023, 03:22 PM   #3835
Rust_never_sleeps
struggled unsuccessfully to get the brake lines clamped to the xmember.
Going to punt on this, get the lines bled and leak tested, then drive the ***** up on ramps to secure those lines with some damned room to work
Old 05-25-2023, 03:22 PM   #3836
Casper42
Casper42's Avatar
had this little guy recreated for my truck
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 05-26-2023, 06:44 AM   #3837
ghackett1
68 C10 Longbed
ghackett1's Avatar
Changed the rear end fluid. Checked axles seals and all dry so the 12 bolt is good to go.
Old 05-26-2023, 11:12 AM   #3838
wpsharpshooter
Thats cool.. Id like to do something like that.. But the glovebox door isnt original to my truck.. Any other way to get that info than from the sheet on the glovebox?
wpsharpshooter is offline   Reply With Quote
Old 05-26-2023, 05:28 PM   #3839
Casper42
Casper42's Avatar
if you don't have the SPID or buildsheet under the seat, then you can still create one based on what your truck's details and options are, along with the VIN. It will be probably really close, or at minimum what you want it to show. If you don't already know, you might get fully educated on what all the options were available. It'll be more of a crap shoot on a few items like tires, gearing, etc. Either way, it's easy to determine what the manufacture list prices were on every item.
Old 05-27-2023, 02:04 PM   #3840
72c20customcamper
72c20customcamper's Avatar
I hate working on hoods .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-27-2023, 05:22 PM   #3841
HalfBrit
Managed to mount the radiator overflow tank and PS reservoir, today. Waiting on a couple of 90 degree fittings so I can connect the last PS hose.
HalfBrit is offline   Reply With Quote
Old 05-27-2023, 05:36 PM   #3842
72c20customcamper
Inside painted
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-27-2023, 06:13 PM   #3843
Finally finished the install of the 84 Suburban 31 gallon gas tank
Old 05-27-2023, 08:51 PM   #3844
EdwardSams
Went in for an inspection, rolled out with an oil change, recharged air conditioning, and topped off fluids.
EdwardSams is offline   Reply With Quote
Old 05-27-2023, 09:49 PM   #3845
Casper42
Casper42's Avatar
Detailing - cleaned all the window rubber gaskets and polished all the window brightwork. Good for another 51 years
Old 05-27-2023, 10:39 PM   #3846
body bolt
I had somehow missed this thread. Very impressive!
body bolt is offline   Reply With Quote
Old 05-27-2023, 10:52 PM   #3847
KQQL IT
At the body shop.
KQQL IT's Avatar
Fresh layer of penetrol.
Old 05-28-2023, 05:59 AM   #3848
ghackett1
68 C10 Longbed
ghackett1's Avatar
Took driver side door apart and installed new glass and track, lubed up channels and coated bottom inside of door with POR15. Also added correct spacers to window crank and door handle. Window and door operate as they should now.
Old 05-28-2023, 11:27 PM   #3849
pjmoreland
pjmoreland's Avatar
I found the squeak that was coming from the back of my cab. I tightened the rear cab mounts, and the noise is gone.
Old 05-29-2023, 10:08 AM   #3850
72c20customcamper
Found the cranking problem with the 72 . Couple of messed up teeth on the flex plate . New one is on the way should be here tomorrow.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
