Old 06-05-2023, 10:34 AM   #1
KyleSeal
KyleSeal's Avatar
Need Some Info with this Drop
So currently on my 67 I am running a 5.5 front and 7 rear drop. This is achieved with 5 inch drop springs and 2 inch blocks in the rear, 3 inch springs and 2.5 inch CPP disc brake spindles in the front. I am using the CPP tubular control arms in the front as well, stock crossmember.
How have yall gotten around the inner fender issue? I have stock replacement inner fenders, but man its close, which I knew would be close but not this close. I assume I will need to section the inner fenders and move them up. I also assume I would need to move the battery, is that true?
Can I get some pictures of how everyone is going about doing this? Id rather not buy a set of aftermarkets since Ive already got some factory style ones.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 06-06-2023, 08:48 AM   #2
SCOTI
SCOTI's Avatar
Re: Need Some Info with this Drop
Interference will/can be dependent on the front tire OD. What size wheel/tire combo are you running?
Common solutions are no fender wells, sectioned & raised stock stuff, or aftermarket fabricated pieces.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-06-2023, 01:36 PM   #3
KyleSeal
KyleSeal's Avatar
Currently there are 235/75/15s, stock 4 nub wheels. These tires are some off a truck that came into my work and needed new tires (rubbed terribly) so I threw them on my truck as rollers until the truck is on the road again. So Im not stuck to this size, although it is a nice looking size.
Old 06-06-2023, 01:45 PM   #4
SCOTI
SCOTI's Avatar
Those 28.8" front tires are part of the issue on 'what fits'. No taller than 28" up front helps.
If I were a betting man, I'd bet the most common front tire height ranges from 27-28" max. 27" would likely clear stock wells & anything taller is where mods or the aftermarket stuff comes into play. A 215/75 or 225/70 15" tire puts you around 27.4-27.5" front tire height.
Some guys run short (<27" up front) tires & have no clearance issues, but the combo doesn't look right to me as I like the wheel opening filled vs a large gap/space.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-10-2023, 01:19 PM   #5
PowerdbyChevy79
PowerdbyChevy79's Avatar
With that drop you should stay 27" and under.. a 255/60 is around 27.. and it minimizes wheel gap.. just depends on the wheel type and look that your going for..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
custom, drop, inner fenders, modification
