Old 06-09-2023, 09:18 PM   #1
cprimo
Two post radios
Previous owner cut dash and put in a then modern single din radio. I don't care for the look of a modern looking radio in a classic truck. But seeing as the dash is cut for a single din, I'm looking for a radio that looks like a two post radio but fits in a single din cut radio slot. You'd think someone would design a two post radio that would slide into a cut dash but still look like a two post but have all the modern features, but I can't seem to find this unicorn.
cprimo is offline   Reply With Quote
Old 06-09-2023, 09:53 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Two post radios
I think you may have to buy a DIN hole cover plate, and cut it out to fit a classic-style 2 knob radio.
Old 06-09-2023, 09:57 PM   #3
cprimo
Re: Two post radios
You would think one of these so called classic car radio companies would make one so it would fit in the cut dash to restore the classic look they claim to sell radios for.
Old 06-09-2023, 11:05 PM   #4
guyryan100
guyryan100's Avatar
Re: Two post radios
Amazon has several basic radios like this
https://www.amazon.com/Bluetooth-Ele...dp/B08L6P6C8B/
guyryan100 is offline   Reply With Quote
Old 06-09-2023, 11:10 PM   #5
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Re: Two post radios
I can't imagine why anyone would build such a thing. How many could they possibly sell? Maybe one. Use a DIN radio or fix the dash & use a 2 post.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 06-09-2023, 11:20 PM   #6
dmjlambert
dmjlambert's Avatar
Re: Two post radios
Well it appears guyryan100 found the unicorn.
Old 06-10-2023, 06:06 AM   #7
Re: Two post radios
A lot of dashes cut for DIN radios. Our trucks are a common vehicle with all steel dash and fairly easily repaired...compared to some vehicles that will be harder to find to cut the patch from not to mention the plastic that's been cut.
Old 06-10-2023, 08:01 AM   #8
cprimo
Re: Two post radios
Thanks guyryan100. I had seen that one for like $30 and read bad reviews but hey its only $30, right?! Special-k just got my truck out of body shop after 15 months, the idea of putting it back isn't appealing to weld, prep and repaint the dash. I think there are more than one 67 twins but there is a need I'm sure for at least 2, lol. Side note for 67 twins: I bought a T5 to put behind 6cyl, swapped tail sections and what not. How do you like the 5 spd behind yours? I have a 3spd now.
Old 06-10-2023, 12:28 PM   #9
jumpsoffrock
Re: Two post radios
Wait.... you put your truck in a body shop for 15 months and didn't ask them to fix a metal dash which is very common to be cut up, and would be very easy to be repaired?
Either way, as you have already found($30; bad reviews) typically the more "gimmicky" a radio is(finding a single din wannabe-double-post), the crappier it is.
Just be careful you don't spend too much time doing yourself an un-favor.
I understand installing radios isn't rocket science, but it does take an afternoon with proper clean-up.
jumpsoffrock is offline   Reply With Quote
Old 06-10-2023, 12:59 PM   #10
roboticjunky
Re: Two post radios
You could try a retro style radio and use one of the face plates. Since it looks like some of their radios are wider than the face plate. Just a thought.
https://www.retromanufacturing.com/p...ant=7979907907
roboticjunky is offline   Reply With Quote
Old 06-10-2023, 01:21 PM   #11
HO455
HO455's Avatar
Re: Two post radios
Here is a link to how I installed a factory radio in a DIN hole. Scroll to post 291. I had the radio modified by Gary Tayman so it has AM/FM and a USB plug for a flash drive. It's been great.
http://67-72chevytrucks.com/vboard/s...698377&page=12
RIP Bob Parks.
Old 06-11-2023, 03:45 PM   #12
jumpsoffrock
Re: Two post radios
My PM box is full, could you give some more info on the USB modification of your old radio? You didn't do it yourself, did you? I wonder how he did it.
Old 06-11-2023, 03:50 PM   #13
dmjlambert
dmjlambert's Avatar
Re: Two post radios
I am not a customer, but he has a good reputation here on the forum
https://www.taymanelectrical.com/
Old 06-11-2023, 04:36 PM   #14
HO455
HO455's Avatar
Re: Two post radios
Gary did mine using Aurora Design components. There are other options I didn't get on mine.
https://www.tech-retro.com/aurora-design/home.html
RIP Bob Parks.
Old 06-11-2023, 06:24 PM   #15
Killer Bee
Killer Bee's Avatar
Re: Two post radios
are these what you're looking for?
RetroSound DIN repair kits
I reckon those faceplates could be trimmed to fit and painted to match dash color to be less conspicuous
good luck!
RetroSound 404-292
Restore the look of your classic vehicle — includes exterior DIN faceplate and shaft mounting brackets
RetroSound 404-292 - Get that vintage look back by installing a shaft-style RetroSound radio in a modified DIN-style opening
RetroSound 294-302 DIN Repair Kit
Restore the look of your classic vehicle — includes mounting bracket and faceplate (Chrome pebbled faceplate)
RetroSound 294-404 DIN Repair Kit
Restore the look of your classic vehicle — includes mounting bracket and faceplate (Black)
