Old 06-13-2023, 02:51 PM   #1
mrobvious34
lowering ls motor mounts?
I know this horse has been beat over and over, but I have found many are having the same problem I am, but I have not seen any threads with a solution. Does anyone make motor mounts that will set an LS lower in between the frame rails? I have a 6.0l/4L80 on GM BBC stands in a 67 SWB. At ride hight my engine sits tilted back 6 degrees, my drive shaft down at 1 degree, and my diff is 2 degrees. I am getting a bad vibration about 60 and need to correct my u joint angles. I have my trans up as high as i can get it (high hump), and would like to drop the motor mounts down to help with the angle. I am running a F-body oil pan and I have plenty of room for it to come down (about 2 inches). Anyone know of any motor mount stands that would sit lower? BTW, i cant remember where i got the trans crossmember but it is one of those M shaped tubular ones to clear the exhaust. I could shim the diff but i would rather not, I dont want a lot of u joint angle
mrobvious34 is offline   Reply With Quote
Old 06-13-2023, 03:41 PM   #2
Joyridin
Re: lowering ls motor mounts?
Is your driveshaft running uphill or downhill? I just rotated my axle so the driveshaft goes uphill. I have it set at 2.5 degrees if I recall.
Joyridin is offline   Reply With Quote
Old 06-13-2023, 03:51 PM   #3
hewittca
hewittca's Avatar
I have the stock small block motor mounts in my truck with the ICT Billet adapter plates and my motor is at 3 degrees down. I have the Holley 302-1 pan which is similar in depth to the F-body pan I believe. I've never measured the gap from pan to crossmember, but its fairly close. There's plenty of room for comfort, but I don't think I'd want it any closer.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 06-13-2023, 05:35 PM   #4
mrobvious34
My truck is in bags and at ride height, it runs down hill (higher at the front, lower in the back) 1 degree
Old 06-13-2023, 05:37 PM   #5
mrobvious34
I may try swapping to those, I am using LSX Innovations adapter plates, they’re are virtually identical to the ITC ones
Old 06-14-2023, 04:01 PM   #6
clay68c10
clay68c10's Avatar
The Hooker/Holley LS stands and mounts keep things low. Check em out
https://www.holley.com/products/ls_p...s/parts/BHS511
And the Speedway version
https://www.speedwaymotors.com/1967-...ck,445271.html
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-16-2023, 01:40 PM   #7
verdell
verdell's Avatar
Have you considered stock 73-87 perches with clamshell mounts?
verdell is offline   Reply With Quote
Old 06-16-2023, 07:32 PM   #8
v30crewcab
v30crewcab's Avatar
I built my own mount setup with some poly mounts from ebay. got it to set pretty low. made a pair of plates for the frame like a 73-87 style for them to weld to.
https://www.ebay.com/itm/40397938776...Bk9SR5b24uiYYg
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-06-2023, 08:01 PM   #9
tallic68
Active Member
Read through my thread. I just went through this. My starting engine angle was 6.7. Got it down to 3 deg.
https://67-72chevytrucks.com/vboard/...69#post9230069
tallic68 is offline   Reply With Quote
Old 09-06-2023, 10:54 PM   #10
bigmoe
bigmoe's Avatar
My engine is 6 degrees down and the rear is 5.8 degrees up. My problem was a low trans hump.
bigmoe is offline   Reply With Quote
