Old 06-30-2023, 01:47 PM   #1
A1971Blazer
A1971Blazer's Avatar
WTB 69-72 4x4 SWB Frame
Looking for a decent SWB 4x4 frame....
bare frame preferred but will consider a roller.
Preferably in the TN, KY, NC, SC, GA, AL, MS, FL region...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-01-2023, 12:03 AM   #2
Tmend
Tmend's Avatar
Re: WTB 69-72 4x4 SWB Frame
I’m curious why not 67-68 as well or are you wanting a blazer/jimmy frame not truck.
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 07-01-2023, 06:55 AM   #3
A1971Blazer
A 68 would work …the reason I didn’t include 67 is that the frame is different where the steering gear bolts on. Of course it can be modified but I was looking to avoid that. Also I have a really good 71 Blazer frame but it’s shorter than the truck frame. Again that could be modified as well but not really wanting to do that either.
Basically just looking for the easiest and quickest way to build a SWB 4x4 without a great deal of fab work. I can do it, but just don’t really want to.
If I can’t find a good frame, I will just have to modify my 2wd frame.
This project is a ways out yet but i’m looking for stuff i will need
1967 C10 Step side
1968 C10 Step side
Old 07-01-2023, 12:28 PM   #4
A1971Blazer
If you haven’t found one by then check back with me maybe we can work a deal. Trans member was swapped by me
Thanks for the offer…by all means put me next on the list.
It will be next year before i start the project…If I don’t find one, i’ll just use the parts off the Blazer frame and 4 link the rear..a trailing arm set up with coilovers might work as well
1967 C10 Step side
1968 C10 Step side
Old 07-01-2023, 02:30 PM   #5
68Custom
Hammer On!
68Custom's Avatar
You won't want a 68 frame either if you're not interested in modifying the frame. Currently I'm working on a 68 K10 and have to modify the frame for power steering by means of CaptainFABs bracket. Just thought you might like to know!
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
68Custom is offline   Reply With Quote
Old 07-01-2023, 04:46 PM   #6
A1971Blazer
Good to know...
I had thought the PS gear mounting surface changed for the '68 MY....did it have the hydraulic ram assembly like the '67 did ?
1967 C10 Step side
1968 C10 Step side
Old 07-01-2023, 05:07 PM   #7
Classic Bowties
Always on the hunt...
Originally Posted by A1971Blazer View Post
Good to know...
No, not on the K frames, no frame mounted power steering gear until 69 on the 4wd's. Imho, your WTB "69-72 4x4 frame" thread is correctly titled and what we would also be chasing for the p/s and upgraded forward spring hanger (also a 69 K frame design change) reasons. Good luck on the hunt! Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our paypal account & info has been changed as of Jan. 2022. Thanks...
Classic Bowties is offline   Reply With Quote
Old 07-01-2023, 06:22 PM   #8
A1971Blazer
More good info….thanks for the input…
1967 C10 Step side
1968 C10 Step side
Old 07-01-2023, 09:34 PM   #9
Seanext
67 4x4 frame also has one year only 3" rear springs.
Seanext is offline   Reply With Quote
Old 07-02-2023, 06:47 AM   #10
CUSTOM/10
CUSTOM/10's Avatar
I've had a few 72 swb 4x4s and each of them had a reinforcement bracket on the inside of the frame for the steering box. They also had a bracket on the driver's side front spring hanger, and an L-bracket on the frame behind the spring to retain the spring in place if the spring should brake. Another difference is the 72s have different / taller rear forward spring brackets. Some of these changes may have started in 71.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 07-03-2023, 07:36 AM   #11
A1971Blazer
A lot of good information...
Looking at the production numbers reveals that there just weren't a great deal of 4WD SWB models produced.
Model years '71 & '72 saw the highest production numbers and, by observation, they populate the list for availability.
The search continues.......
1967 C10 Step side
1968 C10 Step side
Old 07-03-2023, 11:07 AM   #12
Leonard1
Leonard1's Avatar
Would you be interested in a cut down lwb frame? Not mine, but I know where one could be bought.
Leonard1 is offline   Reply With Quote
Old 07-03-2023, 04:31 PM   #13
68Custom
Hammer On!
68Custom's Avatar
The 3" rear springs were used on the '68 K trucks as well. The other oddity about those rear springs is that they start at 3" on both ends but slim down to 2.5" in the middle. NOT any easy solution to replace!
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
Old 04-14-2024, 04:21 PM   #14
best view
Why can’t you just use a 2wd short bed frame
best view is offline   Reply With Quote
Old 04-14-2024, 04:41 PM   #15
Richard
Not a big deal to overcome. I believe when replacement springs are ordered for these the 2.5" leaf is used with wider bushings at the ends.
Richard
Old 04-14-2024, 09:29 PM   #16
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: WTB 69-72 4x4 SWB Frame
71-72 4x4 frames also have an extra reinforcement bracket on the rear spring hangers that are riveted to the underside of the frame rails. 69-70 spring hangers only riveted to the side of the rails. i used 72 blazer rear hangers on my 69 suburban for the extra support. i also installed the steering box inner support bracket from the blazer.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 04-15-2024, 07:43 AM   #17
1970cstblazer
1970cstblazer's Avatar
Gary
My 1970 Blazer has the inner reinforcement bracket for the steering box. The taller rear forward spring brackets began in 1971.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
