Old 04-14-2014, 10:35 PM   #1
BigSix
Power Steering Pump Adaptation to GMC V6?
Any info or pics from folks that have mounted a later model pump to their GMC V6 engines? Working on my power steering conversion and would like to buy a pump...just curious if I am fabbing it all or if there is a combination of brackets that work?
BigSix is offline   Reply With Quote
Old 04-15-2014, 07:20 PM   #2
duallyjams
duallyjams's Avatar
Re: Power Steering Pump Adaptation to GMC V6?
did a search
http://67-72chevytrucks.com/vboard/s...power+steering
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-15-2014, 07:22 PM   #3
MusicMan70
MusicMan70's Avatar
You need to try and get the double groove pulleys for crank and W/P. That is half the battle.
Here is something I fabbed up using this EBay bracket and I think a Buick double groove P/S Pulley/Pump. I had a friend make me an extension to bolt up underneath. My fab skills are basic but this works.
I have also seen some use the chevy big block type of pump with remote reservoir.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 04-15-2014, 07:23 PM   #4
BigSix
Originally Posted by duallyjams View Post
You're the man! And not too far from me!
Old 04-15-2014, 07:24 PM   #5
BigSix
I have a double groove on the crank so I may just try and fab something up to run solely off the unused groove. Is that what you mean?
Old 04-15-2014, 07:32 PM   #6
MusicMan70
MusicMan70's Avatar
Yes, I've seen some people use an idler pulley as well.
MusicMan70
1961 GMC Suburban
Old 04-15-2014, 07:35 PM   #7
BigSix
That makes sense. For me, I wouldn't mind having a separate belt running alternator and power steering just so losing 1 belt doesn't take it all out. I don't think losing a belt is much of a concern though.
Old 04-15-2014, 08:02 PM   #8
duallyjams
duallyjams's Avatar
There are 2 different size double grove pulleys that came on the V6, there also 3 grove pulleys.
James
IG duallyjams
Old 04-15-2014, 08:25 PM   #9
J3500HD
Junior Member
J3500HD's Avatar
If you are interested, I have a V6 power steering pump, brackets and pulleys, and adapters for steering box-to-frame.
J3500HD is offline   Reply With Quote
Old 04-15-2014, 10:20 PM   #10
BigSix
I am interested...pming.
Old 07-02-2023, 03:43 PM   #11
ahaynes106
ahaynes106's Avatar
I know this is very old, but curious about your extension on the bottom. Is it flat or offset? length between bracket bolt and mounting bolt?
ahaynes106 is offline   Reply With Quote
Old 07-03-2023, 07:46 PM   #12
MusicMan70
MusicMan70's Avatar
Ahaynes; The extension on bottom is offset.
The hole I drilled in the bracket arm that sticks out; all I did was remove that front bolt from the engine mounting plate and made a mark and drilled it.
The lower extension not sure of measurement. I had to play around with it a bit to have one of the pulleys line up.
I'll see if I can get you some better pics and a measurement.
MusicMan70
1961 GMC Suburban
Old 07-04-2023, 01:52 PM   #13
MusicMan70
MusicMan70's Avatar
Here’s the belt size I used and some extra pics.
MusicMan70
1961 GMC Suburban
Old 07-05-2023, 01:23 PM   #14
ahaynes106
ahaynes106's Avatar
Great, thanks. I tried to get started making that extension piece, but didn't get far with the holiday. I appreciate the extra pics!
Old 08-09-2023, 02:38 PM   #15
ahaynes106
ahaynes106's Avatar
MusicMan70 thanks for all the pics. I finally got mine in. The ride to work this morning was so nice with the power steering in place. New shocks were nice to.
Old 08-09-2023, 08:07 PM   #16
MusicMan70
MusicMan70's Avatar
Your welcome Ahaynes;
Your set up looks great!
MusicMan70
1961 GMC Suburban
