Old 04-01-2023, 03:54 PM   #101
olrosa
olrosa's Avatar
Re: Grandpa's OG 1978
Originally Posted by evan View Post
Have you thought about spraying the hinges to match the fenders? I bet the shape of them wouldn't jump out at you if the finish matched. Even if you left the shock/spring and hardware raw.
Not a bad idea
olrosa is offline   Reply With Quote
Old 04-10-2023, 05:48 PM   #102
olrosa
olrosa's Avatar
More pictures for y’all
Old 04-11-2023, 09:45 PM   #103
PowerdbyChevy79
PowerdbyChevy79's Avatar
Looking good brother!!
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 04-12-2023, 10:46 AM   #104
olrosa
olrosa's Avatar
Thank you. Now for the not so good news. Drive shaft came apart on the Dyno while being tuned. LOL stupid hot rods. I knew the tube was probably a little smaller that it should be, but I didn’t think it was an issue. I am not make a lot of power. 380-400 at the crank. Like 310 at the wheels
Old 04-12-2023, 07:09 PM   #105
Rickysnickers
Wow, bummer!!!
Old 04-12-2023, 08:49 PM   #106
evan
evan's Avatar
Wow! If it didn’t tear anything up it’ll be worth it for the bragging rights.
Evan B.
evan is offline   Reply With Quote
Old 04-13-2023, 11:22 AM   #107
olrosa
olrosa's Avatar
Beat the hell out of my brand new exhaust, rear pinion needs replaced. Surely could have been worse. Pisses me off, but it is a fairly easy fix. Just have to throw dollars at it. That's the crappy part. Ugh, I'm tired of spending money LOL
Old 04-14-2023, 10:39 PM   #108
naphtali5725
naphtali5725's Avatar
Hope you get it fixxed quickly!!
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 05-31-2023, 01:19 PM   #109
olrosa
olrosa's Avatar
Exhaust is fixed, now I’m starting to button up interior, under hood and A/C
Here are a couple pictures
Old 07-10-2023, 08:14 PM   #110
olrosa
olrosa's Avatar
Here are some interior pictures. Dash and door panels recovered and Dakota Digital gauges
Old 07-13-2023, 09:45 PM   #111
3drburb
That turned out great.
3drburb is offline   Reply With Quote
Old 07-14-2023, 08:41 AM   #112
Rich84
Rich84's Avatar
Great Truck!
Rich84 is online now   Reply With Quote
Old 07-14-2023, 06:31 PM   #113
olrosa
olrosa's Avatar
Thank you
Old 07-14-2023, 06:32 PM   #114
olrosa
olrosa's Avatar
Originally Posted by Rich84 View Post
Great Truck!
Thank you!
Old 07-15-2023, 10:31 AM   #115
TKCR
TKCR's Avatar
Very Nice! You did an excellent job!
Those belts need restored also. Here’s a set in Buckskin, before & after. These got new webbing.
Old 07-15-2023, 01:24 PM   #116
olrosa
olrosa's Avatar
Thank . I took my seatbelt s out and cleaned them. They look great
Old 07-15-2023, 01:40 PM   #117
TKCR
TKCR's Avatar
Awesome! Truck looks really good.
Old 07-21-2023, 08:23 AM   #118
PowerdbyChevy79
Truck looks really good with them rallies.. how are you liking that QA1 setup?
1966 C10 "Mary"
Old 07-21-2023, 09:52 AM   #119
olrosa
olrosa's Avatar
Thank you. The QA1 setup is awesome!
I’m also getting some 20” rallies. I think that will make it look better.
Old 07-21-2023, 10:41 AM   #120
rdc72
Can you describe how the QA1 ride quaility is vs stock, what front spring rate did you go with and rear? I am just about to pull the trigger on buying the full front and rear QA1 set-up, just wanted to try and get a little insight as to how the driving quaility is first! A lot of cheddar to spend if its not extremly better than stock?
thanks
rdc72 is offline   Reply With Quote
Old 07-21-2023, 01:59 PM   #121
olrosa
olrosa's Avatar
thanks
Describing is hard LOL. I'd say stiffer than stock, but way better, if that makes sense. Like a regular car vs a sports car. Get the sway bar! Barely any body roll. It handles excellent. Just to be clear, i only have the front setup with the QA1 crossmember as well. The setup still works great. I did put QA1 shocks in the rear.
That being said, I had the full setup on a '66 that I built as well. And I loved that setup too. I am a big QA1 fan. Great quality and performance. Worth the $$$
I did not use the rear setup on my square because it was already C notched and I did not want to remove it. It was welded in. The full kit is better all around. And I cannot adjust my ride height in the rear. I may re-do the rear setup at some point.
Hope that helps
Old 07-21-2023, 02:04 PM   #122
olrosa
olrosa's Avatar
Check it out. I got an original “dealer sticker” from the original dealer that my grandpa bought the truck from. I can see where the original one was, right above the tailgate handle. So when it comes in the mail it will get installed.
Old 08-02-2023, 12:02 PM   #123
olrosa
olrosa's Avatar
Installed
Old 08-03-2023, 03:12 PM   #124
rodstored-72
chevy truck fan
rodstored-72's Avatar
very cool!
rodstored-72 is offline   Reply With Quote
Old 08-08-2023, 09:56 AM   #125
rdc72
Looks sweet, thanks for the response Seth, I think I am sold on the QA1! Now to get the purse strings loosened, lol!
