06-24-2023, 08:18 AM | #551 |
Re: My 56 build
Hello Jason, just admiring the work you've done, looks killer. it'll be a beaut!!
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
06-24-2023, 09:20 AM | #552 |
Re: My 56 build
Wow, nice!!!
07-07-2023, 11:15 PM | #553 |
Re: My 56 build
Another day of painting. Doors, hoods underside, and inner fenders in color. Last round of two tone. Nice to be done with that. Takes a lot of time taping. Front clip is next. Getting closer
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
07-08-2023, 04:20 PM | #554 |
Re: My 56 build
Looks great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-09-2023, 08:39 AM | #555 |
Re: My 56 build
Looks very nice. I like the use of the engine stands. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
07-09-2023, 10:48 PM | #556 |
Re: My 56 build
Thanks, I think the most difficult part of painting a vehicle while disassembled is figuring how to hang everything. I happen to be storing a friend’s engine stand and I own one. The 2 have been very useful!
07-10-2023, 08:34 AM | #557 |
Re: My 56 build
i still love that color combo, can't wait ot see it all together
07-10-2023, 10:13 PM | #558 |
Re: My 56 build
do you get many bugs in the paint? if I tried that there would be bugs and dust everywhere. looks good in the pics
07-21-2023, 10:40 PM | #559 |
Re: My 56 build
Only one so far. Picked that one out with tweezers. I have the garage set up like a paint booth. Filters, airflow with fans. It takes 2.5 hours to clean and prep the garage. That sucks! You still get small dust, but you get almost the same results as a booth. I’m going to cut n buff everything anyway.
07-21-2023, 10:55 PM | #560 |
Re: My 56 build
I cut n buffed the underside of the hood before I flipped it over to paint the blue. This way I don’t have to set it upside down on the blue. Also painted the front fenders and upper and lower valances (not really sure what they’re called). Today was my last day spraying blue. One more day spraying bronze. Then painting will be done. Progress
07-22-2023, 08:25 AM | #561 |
Re: My 56 build
Coming out really nice!!. I like it! Steve
07-22-2023, 09:52 AM | #562 |
Re: My 56 build
You appear to be doing a very nice job!!
07-24-2023, 10:34 AM | #563 |
Re: My 56 build
can't wait to see it all together
looks great
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
07-25-2023, 06:57 AM | #564 |
Re: My 56 build
Thanks guys… it’s been a long road. Current goal is to have it driving by spring. Almost done painting, but lots of cut n buffing. The assembly willl be a winter project.
08-19-2023, 11:54 PM | #565 |
Re: My 56 build
Last of the color is down.
08-20-2023, 12:03 AM | #566 |
Re: My 56 build
Bed wood is stained. Just needs to be cleared. Probably next weekend
08-20-2023, 08:32 AM | #567 |
Re: My 56 build
Coming out nice! I love the color combo.
Glenn 1951 3100, Area51 1955 BelAir, 4EVER17 1987 R10, Ethel Copper Hill Rod & Custom http://67-72chevytrucks.com/vboard/s...d.php?t=829856 |
08-21-2023, 01:42 PM | #568 |
Re: My 56 build
Nice! Maybe its the photo, but is there a little groove for the trim to sit in, or is that whole notch just a bit lower?
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
08-21-2023, 07:58 PM | #569 |
Re: My 56 build
All the edges we’re taken down with a dado blade so the stainless strips sit slightly higher than the bed wood. I decided not to use any trim around the inner wheel wells. I couldn’t get the trim to look right around the rounded corners. Just a cleaner look.
08-22-2023, 01:04 AM | #570 |
Re: My 56 build
Wow that's really nice figure! Curly Maple?
08-22-2023, 10:35 PM | #571 |
Re: My 56 build
Yes curly maple. I’m doing a two tone stain. I experimented with it last winter before I planed it down to 3/4”.
Here’s a link to a short video of the final result: https://youtube.com/shorts/Y6x0TttjBIo?feature=share
08-27-2023, 02:15 PM | #572 |
Re: My 56 build
Bed wood is done. Because it’s wood I had to spray it with 2 coats. Let it dry, sand it, then 2 more coats of clear. The grain lifts after the first 2 coats. Turned out pretty nice. Surprising how dark it is after the stain - 2nd picture. Much of it gets sanded off. 3rd picture- sanded. 4th picture sanded after 2 coats. Last picture is the final product.
A short video even! https://youtu.be/OYB-O6iJCKE?feature=shared
08-27-2023, 02:26 PM | #573 |
Re: My 56 build
Looks nice. Maple is one of the hardest woods to take stain uniformly. Did you do both sides or will you oil the back or something else maybe?
08-27-2023, 08:16 PM | #574 |
Re: My 56 build
Both sides are now cleared. I started with the backside on Friday. That received 3 consecutive coats. It’s weather sealed. Amazing how much clear the wood sucks up! You really can’t get a clean finish without letting the first coat soak in and dry. Doing the back first I realized that the same rules apply as varnish. Sanding between coats also applies to automotive clear. Just a wood thing
08-27-2023, 09:44 PM | #575 |
Re: My 56 build
The bed wood looks great. I have the same goal as you. Get all the paint work done before the weather gets cold then assemble over winter. So on your bed wood did you use a oil based stain then automotive urethane clear? I have a scrap piece of pine stained and am going to put some urethane automotive clear on it when I paint the bed sides, gate and front panel to see how it looks. Steve
