#4076 |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
Re: What did you do to your truck today.The 3rd chapter
that's cool, I missed when you first posted you found them - thanks!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#4077 |
![]() Join Date: Feb 2016
It's good to know I'm not the only one who has had a leaking plug weld.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#4078 |
Who Changed This?
![]() Join Date: Jan 2013
Unboxed my new front grille and admired it. Kind of a cheap-looking stamping. Oh, well, at least it's shiny.
#4079 |
I was able to source a new clutch for my 4 seizens #58098 A/C compressor from UAC and, for anyone else who ever needs one, the part number is CL 1654C. I installed it yesterday but saved installing the belt for this cool morning. I had thought a bit about why the previous clutch failed and suspect low voltage at idle caused the clutch to slip and burn everything up as it failed just after sitting at a long red light. I added a fused Bosch relay to feed the clutch coil directly from the battery which should cure/prevent that.
#4080 |
Got stuck with the 72 . I have been pushing not replacing the flex plate . Today the dreaded whine of the bendix spinning on the ring gear . I managed to get a tire iron into the gear and spun the flex plate about 25 degrees . Truck started right up but with the usual grinding noise
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#4081 |
![]() Join Date: Sep 2014
My truck cover was delivered to keep the C10 from getting dusty.
Fitment is very good with added mirror pockets. No cut out for the aerial though, so I just unscrew the antenna. |
#4082 |
![]() ![]() Join Date: Mar 2016
You bet, glad I could help.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#4083 |
![]() Join Date: Feb 2009
236 miles on my truck so I did a oil service. Sort of kidding, the engine is low mile but not THAT LOW, but I did do a few things to it, and it sat six years before the 236 miles. New oil sat with it for 1/2 that, so kind of figured it was due and how nice to do an oil change on a restoration.
I lubed the suspension and steering as well, they were due for certain. Can't get much grease into new parts, but after some miles they'll take it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#4084 |
New starter, pos batt cable, purple(now blue) installed. Have HEI, no yellow wire.
Motor oil and filter. Filled radiator. Filled tranny. Cleaned, gapped, odd side plugs. All plugs will get R&Red once it gets running. Need to get a new Skip White dizzy cap and rotor. To do list is getting shorter. Im happy...Don. |
#4085 |
Well the truck is christened. First time water of any kind has touched it since I finished it .
#4086 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Changed oil & filter after doing the first 500 miles with the break in oil in the truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#4087 |
![]() Join Date: Nov 2018
#4088 |
Who Changed This?
I want one of those, myself! It is indeed in my future.
#4089 |
Bought it from Rock Auto a few years ago. Application is for a 1972 Z28 Camaro and it fits my Q Jet perfectly.
#4090 |
Who Changed This?
Does it have the heat tube valve on the left snorkel?
#4091 |
Nope, you probably need that hooked up in California.
#4092 |
Who Changed This?
Probably, but I'll buy one like yours anyway. The heat tube has never been on the truck in the 42 years that I've known of it.
#4093 |
I finally got my interior finished. Took me a while, but got-r-done. Now I can take the grand kids for a ride.
#4094 |
![]() Join Date: Jan 2007
That looks fantastic!
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#4095 |
The Older Generation
Had some funny noises coming from the drive train on the '72 Dually. I thought it was a front wheel bearing. It's hard for me to tell where noises like that are coming from with my bad hearing. I had an ex-mechanic friend of mine go for a ride with me to see what he thought about it. He said he thought I had a flat tire on the passengers side rear and I had a clicking noise coming from the same area. The outside dual tire was indeed low on air so I aired it up and checked the inside tire. It was completely flat. I thought what the heck is going on here.... I got to checking closer and both of the valve stems were cracked down by the rim. I removed the wheels and tires and took them to my local tire shop and had them put new valve stems in them. The guy that fixed them said it looked like I picked something up between the duals and it rattled around inside enough to break both of the valve stems. Just my luck. There wasn't anything there when I took them off. When I had the wheels off I turned the drum and I could hear something rattling around inside the drum. OK, now I'm going to have to pull the axle and hub/drum assembly off to see what that is. I found that the adjuster spring had broken and the adjuster had dropped out of place and broke some of the other parts and pieces. Luckily I had a pair of new shoes for it so I just had to scrounge up some small parts. I didn't have an H072 adjuster assembly or the spring for it. All of mine are too small so I will have to see if I can find those on the parts board. Seems like it is always something. I guess I'm lucky it didn't lock up on me....
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 08-07-2023 at 10:01 PM. |
#4096 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#4097 |
NOS Studebaker tailpipe extension looks good on a Chevy
#4098 |
I have the same cleaner except mine came with a chrome lid.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
#4099 | |
Thanks Dale. I Have it all put back together except for the adjuster and spring. LockDoc
#4100 |
Who Changed This?
^ Lucky nothing worse happened, Leon!
Put the new grille in my truck over the weekend. Old and new, for comparison. Much better! Next up is paint and install the headlight bezels. Thanks to @Richard for the insert!
