Old 09-20-2023, 06:05 AM   #1
GSOUTHERN
Active Member
LS/6L80E Swap
Does anyone know if the Holley Terminator Max will work with the GM Performance Parts 6L80E part number 19417102. I am being told that it can only be used with the GM Performance engine controller?? Not having any luck getting Holley or GM Performance Parts to answer the phone or return messages.Forgive me if this is already answered in a previous forum, I have searched and had no luck finding anything.
53 3100 Heidts clip Jag rear 350 dual 4 barrels
85 K10 SWB, 27000 original miles, original black paint
87 V10 SWB, 80000 original miles, original white paint
87 R10 LWB LS3 418 CI 6L80
91 V3500 SRW crew cab 454/4L80 80000 orig miles
83 K30 LWB 502/4L80 Arizona Speed&Marine Injection
91 V1500 Suburban Tuned Port 350/7004R
35 Chevy Standard 350/350
GSOUTHERN is offline   Reply With Quote
Old 09-20-2023, 04:11 PM   #2
rdc72
Re: LS/6L80E Swap
Holley just came out with new software for the terminator x max to support the 6L80 Trans. Take a look at thier website. 6L80/90E Transmission Control (PN 558-499) from thier website.
rdc72 is offline   Reply With Quote
Old 09-24-2023, 07:44 PM   #3
1957 Chief
Re: LS/6L80E Swap
I have a production 6L80 and i have the Holley running it.
I read the details on the part number you listed, it seems to have a controller with it, so I am of no help to this conversation.
Bubba
1957 Chief is offline   Reply With Quote
Old 11-28-2023, 08:13 PM   #4
GSOUTHERN
Active Member
Re: LS/6L80E Swap
My mechanic is not able to get the trans to communicate with the computer, has anyone heard of this issue? They have been through the wiring (Holley said they may have a bad connection) all is good still no luck???
Old 11-28-2023, 08:21 PM   #5
Richard
Re: LS/6L80E Swap
Not a clue about the Holley. I understand that when using the oem ECM and TCM the vin number stored in the units much match or communication will not happen. Why I obtained everything from the same car for my swap. The aftermarket has the communication hurdle to overcome on all the newer 6+ speed transmissions.
Richard
