Old 09-21-2023, 04:27 PM   #1
Blue hauler
79' K20 with 1-Ton rear brakes from factory??
I'm restoring a 79' K20 with the 10.5" dia. ring gear 14 bolt.
It has the 13" dia. x 3-1/2" wide rear drum brakes. I'm wondering if this was an option on 3/4 ton trucks? I have only seen these on 1 ton trucks.
Blue hauler is offline   Reply With Quote
Old 09-21-2023, 09:46 PM   #2
400/400
Re: 79' K20 with 1-Ton rear brakes from factory??
Do you have your SPID?
I believe it’s option JB7 for HD brakes.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 09-22-2023, 08:21 AM   #3
Blue hauler
Not sure what the SPID is. Is that the option sheet in glove box? I don’t have that.
Old 09-22-2023, 09:09 AM   #4
Dead Parrot
Years ago, I worked with a guy that special ordered a 75 3/4 ton with a 1 ton rear axle because he was going to set it up with a 5th wheel hitch for his travel trailer. Possible yours was ordered or modified for similar duty. That was a time when you could do a lot of special options on a custom build truck.
Dead Parrot is offline   Reply With Quote
Old 09-22-2023, 09:30 AM   #5
Keith Seymore
Keith Seymore's Avatar
I will check the brake charts on Monday.
I'm at the race track this weekend.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-23-2023, 06:11 PM   #6
Honest Bob
Honest Bob's Avatar
1 ton brakes are JB8 and are hydroboost.
There are a few things that I could see happening.
1) Maybe it was ordered that way. These trucks seemed to be nearly completely customizable from the factory.
2) Someone swapped the rear axle with one from a 1 ton truck. The spring perches would have to be moved (I think the shocks have different mounting locations on 3/4 vs 1 ton as well.) to fit on a 3/4 ton truck.
3) Someone may have upgraded to jb8 rear brakes. I suspect this could be easily done by swapping the entire axle backing plate setup along with shoes and drums and wheel cylinders. I would think there would be brake proportioning valve and master cyl differences as well which if not have been done would cause the rear brakes to lock up well before the fronts.
Honest Bob is offline   Reply With Quote
Old 09-25-2023, 12:30 AM   #7
Blue hauler
Thank you for the info!
I wonder if I need to go with hydro boost set up for the large brakes?
Truck came with vacuum power brakes.
Old 09-25-2023, 11:36 AM   #8
Keith Seymore
Wow.
The '79 brake charts are really oddly formatted and therefore hard to read. And - conveniently charted in metric, so that you have to convert to english.
Short answer: No. The K20 was JB7 only; JB8 not available from the factory.
K
1979-1986
1986 - 2019
Old 09-25-2023, 11:38 AM   #9
Keith Seymore
Here's what they usually look like, for reference (newer version first, older version for comparison).
K
1979-1986
1986 - 2019
Old 09-25-2023, 11:42 AM   #10
Keith Seymore
While quite customizable from a trim or comfort/convenience standpoint, they were not infinitely customizable from a brake standpoint.
The combinations would need to be tested and validated for every model series, wheelbase, CG location, tire option and GVW weight rating, which is why we had the various brake systems defined and released in buckets (ie, JB1, JB3, JB5 etc).
We wouldn't be able to sell a product that had not been fully validated especially after the FMVSS standards were put in place.
K
1979-1986
1986 - 2019
Old 09-25-2023, 11:47 AM   #11
Keith Seymore
If you are super interested in how your truck was equipped you can contact the GM Heritage Center archive with your VIN and they can provide the original invoice, complete with option content, pricing, build date information and the selling dealership.
If your truck was built in Canada, or in the US for Canadian consumption, GM of Canada would also have the info. https://www.vintagevehicleservices.com/
K
1979-1986
1986 - 2019
Old 09-25-2023, 02:42 PM   #12
Blue hauler
Keith,
Thank you so much for the extensive information. I will definitely pursue the vehicle information through the GM Heritage Center. The options decal was no longer in the glove box when the truck was purchased, and I'm wondering if reproduction option decals are available from somewhere. It is a fairly rare truck with the E81 wood bed option. In looking more closely at the VIN tag I realized it is a 78', for some reason I had 79' stuck in my head. I'm guessing someone installed the brakes from a 1-ton onto this truck. The spring perches and shock mounts are factory and not re-welded.
Old 09-25-2023, 04:49 PM   #13
Keith Seymore
Once you have the detail contact site member Chipflyer and he will make an authentic looking SPID for you.
Jeff at https://outintheshop.com/
K
1979-1986
1986 - 2019
Old 09-26-2023, 07:54 AM   #14
Keith Seymore
Keith,
'78 built in Janesville.
I was going to comment if it was a '79 built in Flint I might have seen it go down the line!
K
1979-1986
1986 - 2019
Old 09-26-2023, 02:21 PM   #15
wazzabie
K
Hi Keith, What information is contained in the binder?
wazzabie is offline   Reply With Quote
Old 09-26-2023, 02:47 PM   #16
Keith Seymore
Those are the brake charts from 1969 up to about 2003 or so.
The brake development and brake design/release engineers create these charts based on vehicle testing in order to keep all the parts numbers straight when they release them to production and service.
K
1979-1986
1986 - 2019
Old 09-27-2023, 01:23 AM   #17
wazzabie
K
Wow! That is some very unique documentation. Thank you for sharing. I'm curious what additional brake charts and information you have for a 1978 K5 Blazer.
Old 09-27-2023, 02:39 PM   #18
Keith Seymore
'78 K10516 Blazer (column 10):
1979-1986
1986 - 2019
Old 09-27-2023, 02:47 PM   #19
Keith Seymore
And - since I found another chart - a redo of the K20903.
K
1979-1986
1986 - 2019
Old 09-27-2023, 03:20 PM   #20
Blue hauler
Any ideas on where I could find one of these brake shoe anchor bolt for 14 bolt 13”x3.5” drums?
Old 09-28-2023, 10:35 AM   #21
Blue hauler
Didn't take long to get the vehicle invoice with options list.
Old 09-28-2023, 10:44 AM   #22
Keith Seymore
Noice!! Fast!
Scottsdale with tow hooks, bed mount spare, step bumper, wood floor.
I see it just had a birthday, too. Very early build in the model year. Built in Janesville and shipped to Livingston MT.
Was there a charge for the invoice? When I did mine I think it was $50.
K
1979-1986
1986 - 2019
Old 09-28-2023, 10:47 AM   #23
Blue hauler
Yes, it is still $50 for the copy of invoice.
My favorite part about the truck, other than being a K20 is the E81 wood bed option, very rare, I've only seen several in my life.
Old 09-28-2023, 07:55 PM   #24
cadillac_al
I have a 77 with the rotten wood bed option. The only truck I ever had that the bed floor disappeared. I'm not a fan. They look cool on show trucks though.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-20-2023, 05:58 PM   #25
wazzabie
Would would be "07870 TIME 2.6" on the dealer invoice?
