10-27-2023, 08:56 PM | #4301 |
Re: What did you do to your truck today.The 3rd chapter
Started pulling the motor out of the truck today. Got the 4 speed out and got prepped to yank the motor tomorrow. Then onto detailing the engine bay again and getting the new 327 and 5 speed prepped.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
10-27-2023, 09:04 PM | #4302 |
10-27-2023, 09:38 PM | #4303 | |
“Staring” Staring is a prolonged gaze or fixed look. In staring, one object or person is the continual focus of visual interest, for an amount of time“ That’s one sharp object.
Sam 1972 C10 LWB 2020 Z71 Tahoe |
10-28-2023, 10:06 PM | #4304 |
Got the 350 out today and cleaned a few things up and now moving onto swapping stuff over to the 327 and doing some measurements for the new TKX 5 speed.
10-29-2023, 12:21 AM | #4305 |
I love them Orange color engines
10-29-2023, 08:50 AM | #4306 |
Great work Cboy, that's the first time I see a ballast resister on these trucks ...........
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
10-29-2023, 09:02 AM | #4307 |
Nice to see the progress on your '68 - beautiful truck. Small project for me yesterday. I swapped out my OEM-style starter to a Powermaster 9112 hoping to solve a heat soak issue. Wow - wish I would have gone with a high torque starter sooner. Keep the pics coming!
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
10-29-2023, 10:15 AM | #4308 |
Its there because I un converted the truck from HEI back to points. The previous owner put HEI in and cut the original resistance wire out of the harness. So the resistor is there to be the replacement. Ive been looking locally for a old harness that someone ripped out to just get that wire to swap back in and remove the ballast but no luck so far.
10-29-2023, 01:19 PM | #4309 | |
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
10-30-2023, 02:48 PM | #4310 | |
I am finishing up an intake reseal, new radiator, new timing gear/chain set, and new alternator install. This photo was before I pulled the carb apart, gave it a run through the ultrasonic cleaner, and reinstalled. Now I have a fuel leak at the fuel pump that I guess monkeying around with the fuel line caused. This is the fun stuff right? Still need to repaint the oil filler cap as now it stands out with everything else cleaned up.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
10-31-2023, 06:18 PM | #4311 |
New rear shocks. OEM Spectrum, nothing fancy. For once, things went pretty much as expected ;-)
Spec is for 75#, but there is no way the existing ones were nearly that tight. :shrug: |
11-04-2023, 10:05 AM | #4312 | |
11-04-2023, 10:13 AM | #4313 |
Making some more progress. Got the offset dowel pins in and the got the final runout ran and all set for the tremec. Then got the new clutch installed.
Also this past week got all the stuff being moved over from the 350 to the 327. Just a little more cleanup in the engine bay and this motor will be ready to drop back in to the truck.
11-04-2023, 06:32 PM | #4314 |
Installed the TC boot ring retainer that I bought from board member A1971Blazer. Very nice piece.
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2015 Chevy Tahoe LTZ 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
11-04-2023, 07:27 PM | #4315 | |
Asking for a friend with a Jimmy.
11-04-2023, 07:58 PM | #4316 |
Very nice .
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
11-04-2023, 08:19 PM | #4317 |
Yes, he has them posted under blazer & suburban stuff.
11-04-2023, 08:40 PM | #4318 |
Cool. Thanks.
11-05-2023, 09:26 PM | #4319 |
Got the 327 back into the truck today. Now to start getting the tremec fitted and everything back onto the motor. Another week or two and it should be running again.
11-05-2023, 10:02 PM | #4320 |
Making headway on more wiring.
Electric fans, Lokar kick down, MSD-6AL2, Vintage Air, and MSD HVC II coil all wired up. Sorry, no idea how to flip picture.
"If it ain't broken, fix it 'till it is!" |
11-05-2023, 10:10 PM | #4321 |
Mr. Cheyenne
I do, so Flipped!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
11-05-2023, 10:27 PM | #4322 |
11-05-2023, 11:36 PM | #4323 |
Last Monday had LineX sprayed in the bed.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
11-06-2023, 08:21 AM | #4324 |
Nice job on the Line-ex, great work truckers
11-07-2023, 12:07 AM | #4325 |
Very nice . Good job on color match.
