Old 11-06-2023, 01:45 PM   #276
daveshilling
daveshilling's Avatar
Re: 1958 Apache Big Window Loooooong Bed "Lucky"
Since FlatOut is in SoCal, and I'm just 6 hours north, I got my part super fast and tossed it in yesterday.. HUGE difference in space, and whaddya know, the rear suspension actually has travel now!! I used to think my spring rate was way too high...
Waaay more room with this setup, not to mention the ease of adjustability(which wasn't needed but was appreciated!)
daveshilling is offline   Reply With Quote
Old 11-06-2023, 01:49 PM   #277
daveshilling
More photos where you can see how lowering the center point and mounting below instead of above the link attachment point really added a good amount of clearance.
Clearly, Don has seen this issue numerous times over the years! The kit also keeps a nice geometry that allows these rods to stay roughly parallel with half shafts, which I understand to be necessary for this suspension to function well.
I think I could still find a DIY solution, but it wouldn't look this sexy.
Also check out how perfect the Mustang tank is for providing access to the centerpoint! It looks like I planned it that way all along.
Old 11-06-2023, 01:54 PM   #278
dsraven
that looks good. prolly less tire wear now too as they would likley toe in and out, with the old set up, as your suspension moved. well, maybe not if it couldn't move, lol.
Old 11-06-2023, 02:15 PM   #279
daveshilling
That's a good point, I didn't even consider that defect.. granted they weren't even properly aligned in the first place, but I had more than one issue at hand.
Next up for the rear is seeing if I need to roll/trim the fender lip to clear these 225 BFG's....right now there is enough camber on each wheel to prevent rubbing, but if I correct that, I miiiiiight be in trouble!
Old 11-06-2023, 02:17 PM   #280
dsraven
Personally I like a finger space between but that's just me. You could space the fender away from the box if need be.
Old 11-07-2023, 01:51 PM   #281
daveshilling
I do as well, but not enough to buy new tires or make custom fender extensions Since camber "solves" the problem and its not a commuter, it feels pretty optional...I'll likely add some more clearance in the lip, get the tires in a little closer, and just drive
Old 11-07-2023, 01:59 PM   #282
daveshilling
Drivers side door is looking pretty complete!
This looks like just a regular old boring door... but I have spent HOURS to get to this point.
  • Fixed the door bottom and cracked hinge bolt area
  • new door seals
  • new window felts
  • new vent window rubber
  • rebuilt the regulators by soaking in Evaporust, greasing everything, and replacing the 3 plastic pulleys
  • Wrestled the window in
  • Wrestled the interior door trim in that was bent to hell and back
  • Added door handles...these should have been included, not optional!
  • Replaced the mirror with an original white round mirror...had to drill out the screws
Old 11-07-2023, 10:27 PM   #283
Kevin_C
looking good. I had considered buying that flip kit back when I bought my flat out kit. I think the price has gone up $100 since. Guess I shouldn't have waited
I just installed some repo exterior door handles and arm rest. I was surprised that the aftermarket interior trim panel did not come with the holes for the arm rest drilled.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 11-08-2023, 12:48 PM   #284
daveshilling
What's up build brother!
I drilled new holes and raised the brackets on the rear kit, and I'm also at the very bottom of these coilovers, so you might not need it.
The FlatOut kits sit too high in the rear for my tastes, which is why I adjusted the brackets and narrowed the frame channel. I know you are hoping for yours to come down with some bed wood, but just have someone stand in it and see if you like the height...better to address it now!
Old 12-28-2023, 03:29 PM   #285
daveshilling
The last bit of regular progress has been fueled by one mission: Go on a lil cruise with my Grandpa while he's still around (which isn't much longer).
Grandpa got me started tinkering on things when I was little, so it's only fitting.
Mission Accomplished.
Old 12-28-2023, 07:08 PM   #286
Rickysnickers
Very nice!!!
Old 12-29-2023, 03:47 PM   #287
Kevin_C
Thats awsome!
Old 01-01-2024, 11:43 PM   #288
G&R's57GMC
G&R's57GMC's Avatar
Happy New Year and congrats on mission accomplished !
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 01-02-2024, 12:21 PM   #289
57tailgater
Awesome!!!
57tailgater is offline   Reply With Quote
Old 01-02-2024, 12:27 PM   #290
Tempest67
Tempest67's Avatar
Well done, That is great.
congratulations
Tempest67 is offline   Reply With Quote
Old 01-04-2024, 02:28 PM   #291
daveshilling
Thanks, yall. I'm glad I got to have this moment with him.
I'll probably start tinkering on it again soon enough, it still needs plenty of work... a whole interior, a flip up bed, some wiring clean up, and who knows what else, but that stuff alone will keep me pretty busy
Old 02-26-2024, 07:48 PM   #292
G&R's57GMC
G&R's57GMC's Avatar
Time for an update ?
Glen & Jane's Rides
Old 03-03-2024, 03:20 PM   #293
daveshilling
It SHOULD be, but I haven't touched the truck in a lil bit.
If I do any tinkering right now, its going to be on your 56 big block!
Old 05-29-2024, 12:18 PM   #294
57tailgater
Don't know if you're still looking, but these are still available and the price is dropping and open to offers.
https://www.jalopyjournal.com/forum/...uards.1303192/
