#26 |
Re: inner fender splash guards after Mustang 2 installation
Well, I went the poor man route and converted a couple baking pans that I found at Big Lots (The hotel pans come in standard sizes and the long sides were too long while the short sides were too short. Baking/oven pans come on all sorts of sizes.) the metal is fairly thin, which makes it easy to cut and bend, and one it is screwed down it isn't flimsy.
Also, I used rivnuts, based upon dsraven's suggestion. that meant that I didn't need to cut the opening any more to create an edge for the clip placement that I had planned to use based upon stepside jim's post. Granted, it isn't as professional as stepside jim's, but it does the job. Some pictures - 1. cut and painted, with rubber edging. 2. rivnuts in place. 3. in place - still needs a couple screws.
55 Cameo w/ 409/700r4 |
#27 |
looks great!
what did you use for the rubber edging? |
#28 |
Got this stuff on amazon:
#29 |
Good job, mission accomplished.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
#30 |
looks great. now, what else can I rivnut while I have the tool out.......
#31 |
![]() ![]() Join Date: Oct 2014
Nicely done!!!
#32 |
Nice Job UncleBrad
I must admit, when you mentioned using a baking pan I had my doubts, but it looks great, well done. (maybe a post/sticky should be started for items that can be used for a rebuild that are not 'automotive'?) Lee Green, as a fellow Canuck, you can find the trim at Princess Auto (The Canadian version of Harbor Freight) see link below https://www.princessauto.com/en/9-16...t/PA0008948804
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
