Old 11-15-2023, 03:37 AM   #1
pjmoreland
pjmoreland's Avatar
Decals for 8000 RPM Tach and Vacuum
I designed these decals because I don't like how the text looks on the reproduction lenses for the 8k tachometer conversion kits. The font is wrong, and the numbers aren't aligned well with the tach. Also, they apply the text and green paint both on the back of the lens, but the green paint was applied to the front of the lens on the originals. This makes the reproduction lenses not light up as well at night.
To design these stickers, I scanned an OE 5k tach and vac lens and used CAD software to trace the characters and set the spacing to align with the 8k tach. I borrowed the missing 6, 7 and 8 numbers from a scan of the speedometer.
These decals are cut out of adhesive-backed vinyl. Clear transfer tape is applied to the front of the decal to allow the decal to be removed from the white backing and then applied to the lens. Sometimes portions of the decal don't want to stay attached to the transfer tape, which requires firm rubbing of the transfer tape against the decal followed by peeling it off slowly while checking that each character lifts off the backing.
The original dummy gauge graphics on the lens must first be removed with a small polishing wheel. I used a cheap one from Harbor Freight on my cordless drill. A quick wipe-down with isopropyl alcohol cleans off the residue. Just don't leave the alcohol on there too long, as it can cloud the surface of the lens. By the way, minor waviness in the surface of the lens is left behind from where the graphics were removed. It is possible to see it a little bit if you get light reflecting at just the right angle.
There is a border around each decal that aligns with the circle on the lens. A flat side is provided for setting the orientation. I like to apply a long piece of masking tape to use as a horizontal guide. Don't apply the tape over original text or paint as it may lift off when removing the tape. You've got to be careful not to let the decal touch the lens prematurely as you're aligning it. Hold the lens up to a light so you can see through the decal backing to align it. You can tape down one edge of the sticker while the backing is still on and use the tape as a hinge to set the sticker in place on the back of the lens after removing the backing.
https://youtube.com/shorts/QPzylsrfP-w?feature=shared
If you have a 5k tachometer already and you want to convert to an 8k, then all you need is one of these 8k decals and the 8k tach. You can buy just the tach from npdlink.com. if you need tach/vac tins, member 70shortfleet can modify your originals. He does amazing work.
***EDIT***
I also have KPH decals available.
8k Tach Decal $15 mailed
5k Tach Decal $10 mailed
0-160 KPH Decal $20 mailed
VACUUM Decal $10 mailed
TRANS TEMP Decal $10 mailed
BOOST Decal $10 mailed
Money order or personal check preferred. PayPal accepted, you pay fees
pjmoreland is offline   Reply With Quote
Old 11-15-2023, 03:38 AM   #2
pjmoreland
pjmoreland's Avatar
Re: Decals for 8000 RPM Tach and Vacuum
A couple more photos.
Old 11-15-2023, 04:50 AM   #3
Richard
Will take one of the 8K tach decals to use with my air pressure lense.
Richard
Old 11-15-2023, 07:32 AM   #4
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
I will take a tach and a vacuum. Send me a PM and I will get you paid.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 11-15-2023, 10:28 AM   #5
72CSCC
Nice work. Great contribution.
72CSCC is offline   Reply With Quote
Old 11-15-2023, 10:59 AM   #6
29od1
I'll take 1 tach and 1 vac.
Thanks,
David
29od1 is offline   Reply With Quote
Old 11-15-2023, 11:03 AM   #7
pjmoreland
pjmoreland's Avatar
PMs sent
Old 11-16-2023, 12:19 AM   #8
CarlsLQ9SS
CarlsLQ9SS's Avatar
I’ll take one of each
Carl
1971 GMC short bed, (Henry)
Options I've added, tilt, ac, 8k tach,
Electric speedometer conversion for LS swap,
6.0 with 823 heads and BTR stage 4 truck cam,
4L80e, posi with 3.73 rear end,
Power steering and power brakes
Lowered 5/7. Frame up build.
CarlsLQ9SS is offline   Reply With Quote
Old 11-16-2023, 12:21 AM   #9
pjmoreland
pjmoreland's Avatar
Sounds good. PM sent
Old 11-23-2023, 02:57 AM   #10
Richard
Received the tach decal today. Thank you. Try to dig out the cluster that has the lens I am using soon. FWIU I am scheduled to hang Christmas lights this coming weekend.
Richard
Richard
Old 11-23-2023, 02:59 AM   #11
pjmoreland
pjmoreland's Avatar
I'm glad it made it to you quickly. Other letters I've sent recently have been taking more than a week to arrive.
Old 11-27-2023, 11:41 PM   #12
pjmoreland
pjmoreland's Avatar
I also have km/h decals available.
Old 11-28-2023, 09:31 AM   #13
Sixty7kten
New Member
Interested in one of those! PM sent
Sixty7kten is offline   Reply With Quote
Old 11-28-2023, 06:43 PM   #14
pjmoreland
pjmoreland's Avatar
Here's a TRANS TEMP decal for Sixty7k10
Old 11-30-2023, 08:39 PM   #15
CarlsLQ9SS
CarlsLQ9SS's Avatar
Do you have anymore trans temp decals?
Carl
Old 11-30-2023, 08:43 PM   #16
pjmoreland
pjmoreland's Avatar
I do have an extra one already made. I can make more of any of these decals, by the way.
Old 12-01-2023, 05:14 PM   #17
CarlsLQ9SS
CarlsLQ9SS's Avatar
Can you do a boost decal?
Carl
Old 12-01-2023, 05:19 PM   #18
pjmoreland
pjmoreland's Avatar
Possibly. I would need a very straight-on photo or scanned image of the gauge.
Old 12-01-2023, 05:26 PM   #19
pjmoreland
pjmoreland's Avatar
Are you just using a stock AIR gauge for boost and you just need the word BOOST like I did with TRANS TEMP?
Old 12-01-2023, 07:23 PM   #20
CarlsLQ9SS
CarlsLQ9SS's Avatar
Boost just like trans temp to be used in the same place on a different set of gauges
Carl
Old 12-01-2023, 07:47 PM   #21
pjmoreland
pjmoreland's Avatar
Ok. All of the letters for BOOST are present on the the stock gauges. I'll work on this in the next day or two.
Old 12-02-2023, 02:36 AM   #22
pjmoreland
pjmoreland's Avatar
I made some BOOST decals. Is this what you had in mind?
Old 12-02-2023, 02:56 AM   #23
CarlsLQ9SS
CarlsLQ9SS's Avatar
Yes, that looks good. How much do I need to send?
Carl
Old 12-04-2023, 06:10 PM   #24
pjmoreland
pjmoreland's Avatar
All purchased decals have been mailed out. I can make more for anyone who is interested. If you want something different, let me know.
Old 12-05-2023, 06:06 PM   #25
CarlsLQ9SS
CarlsLQ9SS's Avatar
First shipment received, they look really good!
Carl
