Re: PO has me PO'd
Re: PO has me PO'd
Got the last 8 inches of the gasket installed, seems like Widex and pry tool best suited for the job
Seemed like method would replicate installing spline on screen door, but it didn't prove out to be any guicker then the pry bar, but but the finish on the frame failed, might have to go with plating ![]()
Re: PO has me PO'd
Re: PO has me PO'd
Some place in a desert climate should be a wind wing with this plating
Re: PO has me PO'd
Re: PO has me PO'd
Vent window update
![]() Adjust tension stud
Re: PO has me PO'd
Threads galled
Wonder what size it is?,303 OD have to check TPI, looks like 24 ,278 at the threads ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-21-2023 at 11:31 AM. |
