Old 11-20-2023, 11:29 AM   #1
blazer2007
welding shock mounts on a rearend ?
I have a ford 9 in. I,m putting in my lowered 78 blazer with air bags. Just wondering how strong the shock mounts have to be on the rear, will my 110 volt Lincoln wire feed be good enough .
blazer2007 is offline   Reply With Quote
Old 11-20-2023, 02:28 PM   #2
MySons68C20
MySons68C20's Avatar
Re: welding shock mounts on a rearend ?
Clean metal and grind bevels you'll be fine.
MySons68C20 is offline   Reply With Quote
Old 11-20-2023, 05:19 PM   #3
LS short box
And practice on similar thickness steel prior to welding the shock mounts. Two reasons for that. One it let's you get the voltage right and wire speed right. Also will give a feel for the the gun movement.
Old 11-20-2023, 11:29 PM   #4
Dead Parrot
Take your practice pieces and after welding, smack them with a large hammer and bend with vise and pipe wrench. If they fall apart easily, practice some more.
There should be a settings chart inside the machine where the wire goes. Start with that and adjust as needed.
You may need a 30A 120V circuit. A 140A machine can trip a 20A breaker if you crank it to near full.
Dead Parrot is offline   Reply With Quote
Old 11-21-2023, 11:06 AM   #5
blazer2007
Ok ,I will give it a try. Forgot to mention the rear is empty and sand blasted.
Old 11-21-2023, 11:13 AM   #6
IIGW
in the 80s/90s thats all we had was home depot $399. welders with wire feed fluxcore wire when we built our minitrucks.
We built entire trucks, bagged, hydraulics, body dropped, everything the 'bagged' world has turned into to today, we did it with 110 welders.
IIGW is offline   Reply With Quote
Old 11-21-2023, 01:10 PM   #7
skip99
skip99's Avatar
Thats what i used…worked fine
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 11-22-2023, 11:41 AM   #8
blazer2007
mine is a co-2 argon mix. Does that make a difference from a flux core ?
Old 11-22-2023, 02:22 PM   #9
MySons68C20
That is all I use (Argon C02 mix), you will be fine and it is easier to clean up too.
Old 11-22-2023, 04:32 PM   #10
SCOTI
SCOTI's Avatar
Coil-over mount? Nope. Just a shock mount separate from the actual suspension? Sure....
When selecting the set-up 'settings', I'd put the heat for the thicker material of the 2pcs. You want the penetration on the housing to be solid. Do your practice runs on similar thickness materials as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-23-2023, 11:15 AM   #11
blazer2007
OK ,thanks for all the replies. I have all winter to do this so no hurry.
