Old 11-29-2023, 05:07 PM   #1
Jason Bourne
Junior Member
What Do You Think It is Worth?
Hello this is my 1st post. I have already learned a lot looking through the posts. I anticipate coming back often looking for advice.
My son recently purchased a 1972 C10 and I'm curious what other people think it is worth. He got it for $6K. We have a history of working on his vehicles together and I'm sure we will be putting in some work on this one.
The Truck runs and drives with no issue. The truck originally had a 350 but it was replaced with a 283 at some point. The truck has a TH350 automatic transmission that was recently rebuilt by a reputable shop. The paint looks original. There is some rust in the cab corners and rocker panels. The truck has a small dent in the back of the bed on the passenger side. The truck came with the original 1972 plates which my son thought was cool. I thought they were cool too.
The only issue with the truck is the smell of gas in the cab. We are planning on replacing the sending unit gasket and all hoses attached to the gas tank to see if that will fix the issue.
Jason Bourne is offline   Reply With Quote
Old 11-29-2023, 05:10 PM   #2
Jason Bourne
Junior Member
Re: What Do You Think It is Worth?
A couple more pics showing rust and dent in passenger side bed.
Old 11-29-2023, 05:15 PM   #3
Jason Bourne
Junior Member
Pic of inside.
Old 11-29-2023, 05:49 PM   #4
54blackhornet
54blackhornet's Avatar
Congratulations ! Your son has good taste compared to the ones by me. It’s obvious it’s worth 6K to him.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 11-29-2023, 06:03 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
A '72 C10 would have been equipped with a vapor control system. Is there a canister with hoses on it near the battery? The 283, if it includes that engine's carburetor, may not be plumbed for the closed system. Go here and download the manual for your year truck. It'll have the information you need.
https://67-72chevytrucks.com/vboard/...ghlight=hatzie
As for what it is worth, that looks about right.
~Steven
Simi Valley, CA
Old 11-29-2023, 07:43 PM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Interesting truck. I don't see a "bling" code, but they threw all the moldings on that, which I suppose includes the window trim. But then they threw a painted bumper on it anyway, hmm Seems like a fair deal.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-29-2023, 09:01 PM   #7
body bolt
He did good!
body bolt is offline   Reply With Quote
Old 11-29-2023, 09:08 PM   #8
Jason Bourne
Junior Member
It does have the canister with hoses under the battery. How would I know if it is plumbed correctly? If not plumbed correctly does it affect performance or just emissions?
Also a huge thank you for the manual links!
Old 11-29-2023, 09:18 PM   #9
54blackhornet
I would not worry about that right now. It has other issues I’m sure need attention for safety sake. Father Son projects are great for two reasons. Bonding and learning new skills together. I look back and wish my father would have taught me more about working on stuff but he was just too busy. You two have a great platform to create a real American icon. Just takes imagination and determination. Greatest skills known to man…sorry to get off topic.
71 C-20
07 Magnum RT AWD
Old 11-29-2023, 09:54 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: What Do You Think It is Worth?
Welcome to the best truck board on the 'net! You won't find a better-informed group of helpful folks anywhere.
I can't hazard a guess as to the value of your son's truck, but if he likes it, the price was about right. It's great that you will both be working on it!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-29-2023, 10:18 PM   #11
71CHEVYSHORTBED402
I don't know that engine or carb., but if the canister has PCV, CARB, and TANK ports, then the 5/16" vapor line connects to TANK; a vacuum line connects the carburetor to CARB; and a 1/4" PCV/EEC hose connects the 3/8" PCV hose to PCV. On my BBC, the 1/4" PCV line connects to the 3/8" PCV hose with a tee. I don't know why yours would be different. My vacuum line (CARB) connects to the Rochester carburetor's passenger side upper front port.
A bum hose, canister vacuum diaphragm or cracked canister can affect performance. And if you smell fumes in the garage it probably needs a new/rebuilt tested canister. There's a thread nearby discussing an option using a replacement canister. They don't make the old 1971-72ish cans anymore.
Tony
Old 11-29-2023, 10:59 PM   #12
jumpsoffrock
I'd say the price was fair for today's market.
Cool truck; the rust will more than likely be worse that what you see, sadly.
jumpsoffrock is offline   Reply With Quote
Old 11-30-2023, 01:42 AM   #13
Casper42
Casper42's Avatar
I see this being about $6K
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 11-30-2023, 06:45 AM   #14
weasel29gm
SLOW BUT SURE,BUT CLOSER
Nice ride looks like my first truck I bought in '80. Gave $ 1000 from your pics the trucks are about the same condition. Good find in today's market.
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 11-30-2023, 07:43 AM   #15
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Hi Neighbor!
I do like that color combo!
The plumbing for the canister isn't all that complicated. It is teed off the PVC line and then the other line is to one of the ported connections to the carb. Which from your engine photo I can see the PCV line (that's the big one from the front of the carb to the driver's side valve cover) isn't teed to the canister.
Even if it was the canister would very likely need to be pulled to be replaced or recharged (I recharged my, its a PITA but can be done). Just don't break it, it is even more of a PITA to replace the canister with a correct period one. Don't ask me how I know that ;-)
Though checking those gas lines in the cab is a good thing to check. Actually all the gas lines should be checked IMO, there are little ones under the cab too, so don't miss those!
Welcome to the forums! Here is a flip for your cab photo ;-)
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 11-30-2023, 08:44 AM   #16
1970cstblazer
1970cstblazer's Avatar
In this economy and the market conditions for all things '67-'72 GM trucks, he did ok.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 11-30-2023, 08:50 AM   #17
ghackett1
68 C10 Longbed
ghackett1's Avatar
Nice truck. In South Florida where I’m at 6K is a fair price, it may go 9-10K to the right person. Long bed & rust/body hurt.
ghackett1 is offline   Reply With Quote
Old 11-30-2023, 09:04 AM   #18
The window trim only comes with trim levels Custom Deluxe and up. The side trim came with the deluxe 2-tone option but could also be ordered as their own options
Old 11-30-2023, 12:32 PM   #19
71CHEVYSHORTBED402
That truck has the window trim, but I don't see a SPID option. Perhaps it was added later.
Tony
Old 11-30-2023, 12:57 PM   #20
Casper42
Casper42's Avatar
nearly the same for me, but in 1982, also for $1000. Mine was a '69 GMC Sierra Grande
Old 11-30-2023, 01:32 PM   #21
1970cstblazer
Lightbulb Re: What Do You Think It is Worth?
That $1000 is now the equivalent to $3954 right now.
Old 11-30-2023, 01:49 PM   #22
71CHEVYSHORTBED402
That's interesting. What was a 71 Chevy new, 3Kish? 3K in 1971 is supposedly 22.7K today. A new Chevy costs about 50K plus. To think a 1971's material are >>>>>>>today's builds.
But you know, new trucks have multi and multi-purpose tail gates now. The old tailgates only opened and closed like a tailgate.
Tony
