10-29-2023, 09:12 AM | #3576 |
Re: PO has me PO'd
I like to tape every couple inches, making sure the back of channel stays engaged, thats where the tape helps
Catching the channel pry down and push up on the tool, you'll see when you actually do it Headlamp really helps to see Don't let it out of your sight 16985850637243555851802622212635 by [url=https://www.flickr.com/photos/97391199@N06
11-01-2023, 09:39 AM | #3577 |
Re: PO has me PO'd
Ok stop at this point, and get the gasket over the L bracket
Helps to tape lower channel to avoid pulling gasket out of channel 16988456040303382952337659992035 by [url=https://www.flickr.com/photos/97391199@N06
11-01-2023, 07:42 PM | #3578 |
Re: PO has me PO'd
I see this is a tedious process need patience of a saint
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-02-2023, 08:23 PM | #3579 |
Re: PO has me PO'd
ah yeah, I work on it awhile then put it aside
11-03-2023, 10:28 AM | #3580 |
Re: PO has me PO'd
Had to blow my fender apart to get at the lower hinge bolts
Glad I did found alot of unfinished welds, and spider webs 16990213731915127837025528396484 by [url=https://www.flickr.com/photos/97391199@N06
11-05-2023, 10:11 AM | #3581 |
Re: PO has me PO'd
Thing is, this is just a trial run, see if I can do it.Not happy with the paint adhesion, chips easily
Wanted to ask you a couple questions about powder coat
11-05-2023, 09:12 PM | #3582 |
Re: PO has me PO'd
pm sent
11-06-2023, 09:03 AM | #3583 |
Re: PO has me PO'd
11-15-2023, 12:46 PM | #3584 |
Re: PO has me PO'd
Any body remember this stuff in their trunk
17000666290934071350952786655852 by [url=https://www.flickr.com/photos/97391199@N06
11-16-2023, 12:22 AM | #3585 |
Too Dumb To Know Better
Re: PO has me PO'd
Splatter paint. I remember it well.
11-16-2023, 09:36 AM | #3586 |
Re: PO has me PO'd
I thought that is what it used to be called, had little specals of turquoise in it
Now krypton calls it stone course texture, obsidian Have to check how strong it bonds to the metal, seems pretty good after drying for 2 days, have use the putty knife test
11-17-2023, 09:15 AM | #3587 |
Re: PO has me PO'd
Tough stuff, used to have this stuff in the trunk of my 62 Chevy, only it had turquoise speckled
17002261376286937009066607236262 by [url=https://www.flickr.com/photos/97391199@N06
11-17-2023, 09:17 AM | #3588 |
Re: PO has me PO'd
17002269702037740125196384264484 by [url=https://www.flickr.com/photos/97391199@N06
11-17-2023, 10:47 AM | #3589 |
Re: PO has me PO'd
Got the last 8 inches of the gasket installed, seems like Widex and pry tool best suited for the job
Seemed like method would replicate installing spline on screen door, but it didn't prove out to be any guicker then the pry bar, but but the finish on the frame failed, might have to go with plating 17002318377631316869095308798981 by [url=https://www.flickr.com/photos/97391199@N06
11-17-2023, 11:27 AM | #3590 |
Re: PO has me PO'd
11-17-2023, 11:34 AM | #3591 |
Re: PO has me PO'd
Some place in a desert climate should be a wind wing with this plating
1700235047741738472027850013897 by [url=https://www.flickr.com/photos/97391199@N06
11-20-2023, 12:30 PM | #3592 |
Re: PO has me PO'd
11-20-2023, 12:34 PM | #3593 |
Re: PO has me PO'd
Vent window update
17004976415195996873084173219018 by [url=https://www.flickr.com/photos/97391199@N06 Adjust tension stud
11-21-2023, 11:24 AM | #3594 |
Re: PO has me PO'd
Threads galled
Wonder what size it is?,303 OD have to check TPI, looks like 24 ,278 at the threads 17005798249731050062899400830680 by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-21-2023 at 11:31 AM. |
11-28-2023, 09:41 PM | #3595 |
Re: PO has me PO'd
17012154716626842701964752200098 by [url=https://www.flickr.com/photos/97391199@N06
The post on the right is a 5/16×24 Still trying to figure out the left post They are symmetrical, meaning driver side to passenger side, if you remove latch handle and insert from other side of the glass
12-03-2023, 06:04 AM | #3596 |
Re: PO has me PO'd
Total frustration over the last 3 days
Can't get the vent window to mount up to the. Frame and gasket 17015308650872776201514556474862 by [url=https://www.flickr.com/photos/97391199@N06 Only thing I can come up with is the angle of the mounting post The second window seems to fit better but not perfect
12-04-2023, 08:34 PM | #3597 |
Re: PO has me PO'd
Tears on my tablet
Today and tonight, my special son lays in the ICU, machines keeping him alive Please pray for my son Jeremy
12-05-2023, 04:10 PM | #3598 |
Re: PO has me PO'd
Sending prayers for your son.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
12-05-2023, 07:42 PM | #3599 | |
Re: PO has me PO'd
Jess
12-05-2023, 09:34 PM | #3600 |
Re: PO has me PO'd
Thanks guys, means alot
Outta my hands and into God's Next 2 days will tell
