Carrier bearing insulator ?
Has anyone ever put a thin piece of rubber between the carrier bearing where it mounts to the frame ? Cant see where this would hurt anything and may cut down vibration etc. Your thoughts ?
Who Changed This?
![]() Join Date: Jan 2013
Re: Carrier bearing insulator ?
I think that re-balancing the driveshaft would be a better option, if there is vibration from it. It already has a neoprene doughnut between the bearing and the pedestal mount.
![]() Join Date: Feb 2016
If the drive shaft components are in good shape and the U-joint angles in specification there should be no noticeable vibration.
You may end up causing problems down the road if the rubber allows the carrier to move around under high load conditions. In today's vehicles with NVH being a priority I've not seen any OE rubber mount the carrier bearing. The rubber bushing in the carrier bearing is supposed to absorb normal vibration.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
425hp409
![]() Join Date: Oct 2008
For those of you that use a center carrier with a 2 piece small block driveshaft, showcars.com has one with a polyurethane bushing. It is their part #6668.it fits cars 58-64 and trucks with a 2 piece driveshaft, except some big blocks. I had a problem with vibration on hard acceleration on a 63 Impala with a 327. The #6668 fixed it.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
