Old 07-06-2020, 08:03 PM   #1651
57taskforce
All about them K’s
57taskforce's Avatar
Re: post your 67-72 4x4
Originally Posted by HVACMAN View Post
Thanks so much for clarifying. I have a lot to learn!
So if I am following you correctly since I am currently running a t350 I can assume that I likely have a smaller diameter input shaft version of the np205.
Is the 700R4 the best OD auto for this NP? Or does one of the the newer electronic versions (other than the 4L80E) mate up well?
Thanks again!!
The 700r4 will work with the case you’ve got. Several people on here have done that conversion. The th350 205 is the actually the best one to have for that conversion.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 07-07-2020, 01:52 PM   #1652
jjzepplin
jjzepplin's Avatar
The 700r4 will need a new adapter type output shaft to mate to a 205. Not hard to do but make sure you get a 700r4 that is 1986 or newer as it is a stronger unit. The older ones should be avoided if possible. You can read up on it. I rebuilt my 700r4 with all B-M internals etc and was easy to install the new shaft at that point.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is online now   Reply With Quote
Old 07-14-2020, 11:15 PM   #1653
68Custom
Hammer On!
68Custom's Avatar
Here's my '68 K10 I brought back from Colorado the last weekend of June. Near as I can tell it's the original 250, SM465, and T221 setup. The frame matches the VIN as well. It still has the closed knuckle D44 and I believe the rear axle is a 12 bolt but I haven't got that far yet. I've rebuilt the carb, gapped the plugs (some had no gap), and corrected timing and it runs pretty good, though smokes a bit. It came with some odd bucket seat and I'm searching for a 67-68 bench seat to fix that issue. The cab needs some attention in the usual locations. The fenders are crinkled pretty good and the grille will need to be replaced as it got bent too. I was told it was an old farm truck and it shows, but the bed is from a newer model and in good condition for its age. The hubs are an interesting situation. The driver side has a full time cap and the passenger has a Warn hub. I wish I could find another one and get rid of the cap. All in all, I'm excited for this project. I've been looking for a K for a long time.
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
68Custom is offline   Reply With Quote
Old 07-14-2020, 11:44 PM   #1654
57taskforce
All about them K’s
Heck yea! That’s a great looking ‘68. Other than the bed and the seat it looks to be pretty original. What are your plans for it? Welcome to the 67-72 K club!
Tyler
Old 07-15-2020, 06:56 AM   #1655
2 Stovebolts
Great score...Now the fun begins.....
2 Stovebolts is offline   Reply With Quote
Old 07-15-2020, 10:47 AM   #1656
68Custom
Hammer On!
68Custom's Avatar
The plan is to get it back to original look and feel as much as I possibly can. I'd like to keep the closed knuckle but understand parts are getting harder to come by, especially the hubs. Based on what I can see (no SPID) the paint is the 506 Medium Blue Poly and I'd like to keep it that way too.
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
Old 07-15-2020, 02:43 PM   #1657
HVACMAN
Thanks JJ!
HVACMAN is offline   Reply With Quote
Old 08-09-2020, 11:37 AM   #1658
birdistheword
birdistheword's Avatar
Haven't been on this site for a while. Here's my 69 original paint K10 that I put 3/4 ton axles under. Hopefully LS swapping it next year.
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1979 Chevy K30 dually currently in pieces
birdistheword is offline   Reply With Quote
Old 08-09-2020, 11:41 AM   #1659
57taskforce
All about them K’s
Awesome truck!!
Tyler
Old 08-09-2020, 11:51 AM   #1660
Thealien
Thealien's Avatar
Originally Posted by rowdy11 View Post
I've got the 6L90 with my NP205 (kept the stock trans crossmember and location but fabricated a few mods). Happy to share any lessons learned as it's a bit harder to find LS swap info with a transfer case mixed in on the board.
I'm wiring my LS engine as I write this...prepare for a lot of work with an LS swap but I get more and more excited each day I make progress!
@rowdy11
I wrote this back in 2009
MATING 4L60 TO NP205
Old 08-09-2020, 05:22 PM   #1661
IronCanine
I'm trying....
IronCanine's Avatar
I like the color combo.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 08-09-2020, 07:31 PM   #1662
rowdy11
Hey Rowdy11...Had to read through all of your build thread before responding and now have a full page of new questions! Won’t ask them all now, but will definitely keep your offer in mind!
Gotta admit your experience scares me a little as I do not want to (or need to) dismantle my truck. That band saw action would be a challenge with the np205 in the truck.
I am hoping to keep the NP in place and “slide in” an OD Tranny and LS motor.
That’s sounding a little simplistic after reading your thread.
Maybe the Sniper add to the existing 402BB is more in the cards.
Sure appreciate all of the comments and offers for assistance !!!
6L90e six speed sounds awesome! Extra challenges with that set-up I am guessing?
You bet! Happy to answer any questions and promise not to hide either the good or the bad...it's been a big learning experience for sure!
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 08-09-2020, 07:32 PM   #1663
rowdy11
@rowdy11
Very nice write up!
Lola: My Moon Shot
Old 08-17-2022, 07:58 PM   #1664
best view
To the top
best view is offline   Reply With Quote
Old 08-17-2022, 10:34 PM   #1665
Willowrun
Willowrun's Avatar
Last weekend.
Old 08-19-2022, 01:16 PM   #1666
57taskforce
All about them K’s
Heck yea!!! Looks like a good time!
Tyler
Old 08-19-2022, 07:20 PM   #1667
72ochre
Junior Member
72ochre's Avatar
My work in progress. From C20 to K10.
72ochre is offline   Reply With Quote
Old 08-20-2022, 05:20 AM   #1668
Louisvillekytruck
Nice work
Louisvillekytruck is offline   Reply With Quote
Old 12-25-2023, 12:00 AM   #1669
Rush4x4
Rush4x4's Avatar
My Dad's truck
Rush4x4 is offline   Reply With Quote
Old 12-25-2023, 12:38 AM   #1670
davischevy
davischevy's Avatar
My K10 before I took it apart.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 12-25-2023, 09:42 AM   #1671
allchevy58
allchevy58's Avatar
Haven't posted on this thread since it was painted. All painted, got the bed LineX done and this week it goes in for some clear bra.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 12-25-2023, 09:02 PM   #1672
davischevy
davischevy's Avatar
That sure is a purdy truck. I like the Monte Carlo too.
other Larry
Old 12-27-2023, 10:47 PM   #1673
allchevy58
allchevy58's Avatar
Thank you, the Monte Carlo is a 71' and nice road car.
Old 12-28-2023, 08:04 AM   #1674
Couldn't be better
What a '70s time capsule. I had a '72 blazer with the chrome smoothies and other accessories. Dual auxiliary tanks was one of the upfits. Looks good here and looks great now!
Old 12-28-2023, 09:16 AM   #1675
davischevy
davischevy's Avatar
Couldn't be better
Those wheels are 16.5 x 8.
other Larry
