Old 01-01-2024, 02:28 PM   #76
Stickman
Stickman's Avatar
Re: 1970 C10 ChassisFab Build Thread
He's on Instagram as 72_Plaid_Sub
Stickman is offline   Reply With Quote
Old 01-05-2024, 02:35 PM   #77
nicklear36
nicklear36's Avatar
Got the flip up license plate installed! The hitch is totally hidden now and doesn't hang below the bumper.
This is a cheap universal hitch I bought off Amazon for $150 that I wanted to make work since the only other C10 hidden hitch available is like $400. It took a lot of work to mod the bumper brackets and drill some holes through thick steel, but I'm excited that it all worked out. Just needs some paint touch ups now.
nicklear36 is offline   Reply With Quote
Old 01-08-2024, 04:52 PM   #78
nicklear36
nicklear36's Avatar
Parking brake installed! This is just a cheap 330 lb-ft linear actuator that will be wired to a maintained parking brake button/switch and double pole relay.
Old 01-08-2024, 06:09 PM   #79
Shifty One
Shifty One's Avatar
Farm out!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 01-08-2024, 07:53 PM   #80
zicc1835
zicc1835's Avatar
Originally Posted by nicklear36 View Post
Parking brake installed! This is just a cheap 330 ft-lb linear actuator that will be wired to a maintained parking brake button/switch and double poll relay.
that's nifty
zicc1835 is offline   Reply With Quote
Old 01-11-2024, 11:40 AM   #81
rodstored-72
chevy truck fan
rodstored-72's Avatar
nick, very cool parking brake idea... would you be willing to share a little more detail(s) on what used & install methods? IE: specific cable routing and components - pics too . I would like to try this on my '86 build... if not offended... !!
rodstored-72 is offline   Reply With Quote
Old 01-11-2024, 04:38 PM   #82
nicklear36
nicklear36's Avatar
Absolutely! Here's all the parts I will be using. What's nice about this setup is you can mount the actuators and cable brackets anywhere you want to to clear any frame accessories.
Relay:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Cable Connector:
note: only need the cable connector from this kit. I've search everywhere for the single part but I could not find one!
Actuator:
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Button:
https://billetautomotivebuttons.com/...mergency-brake
LMC Truck Park Brake Cables and Brackets:
-34-1251 (x2)
-34-3121 (x2)
-34-3800 (x2)
-34-3838 (x2)
-34-3928 (x2) (cut down because it will be too long)
https://www.lmctruck.com/1967-72-che...g-brake-cables
Old 01-16-2024, 02:10 PM   #83
rodstored-72
chevy truck fan
nick, thank you! appreciate the links & knowledge. I am hoping that it can "universal install" onto my '86 C10 I am assuming that the parts are descent weather acceptable?
Old 01-17-2024, 03:35 PM   #84
nicklear36
nicklear36's Avatar
Amazon states they are IP54 rated, which should be fine on the undercarriage of a vehicle. If you drive your truck in the rain though, a splash shield of some sort would help give some peace of mind.
Old 01-28-2024, 08:21 AM   #85
hewittca
hewittca's Avatar
Great progress! That hidden trailer hitch is sweet. We will have to see some pics of it in use once you start haulin' with it! I like the random shop buddy pics. And that actuated parking brake is trick! That is an awesome idea. I could have used something like that on mine. With the exhaust tucked up in the frame I had a hard time routing the brake cables. They still rub and bind on the exhaust a bit and cause the pedal to have trouble returning.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 01-29-2024, 02:47 AM   #86
nicklear36
nicklear36's Avatar
Thanks all for the words of encouragement! Pops helped me move the frame to his place today to give me some more space at my house. On to phase two!
Old 02-12-2024, 02:00 AM   #87
nicklear36
nicklear36's Avatar
Getting there
Old 02-12-2024, 12:12 PM   #88
rodstored-72
chevy truck fan
nick, loving the update. was wondering what you used for the radiator pipe and did you make yourself or farmed it out?
thanks!
Old 02-12-2024, 01:16 PM   #89
nicklear36
nicklear36's Avatar
thanks!
I appreciate it! It's an aluminum intercooler pipe with some silicone hose attachments on each end. Had to trim one side of it.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Old 02-12-2024, 08:45 PM   #90
1972CheyenneSuper
1972CheyenneSuper's Avatar
That's a beautiful rolling chassis! That orange just pops. I'm along for the ride.
1972CheyenneSuper is offline   Reply With Quote
Old 02-16-2024, 10:22 PM   #91
zicc1835
zicc1835's Avatar
Getting there
awesome, good lookin, love all the detail
Old 02-17-2024, 11:09 AM   #92
raggedjim
raggedjim's Avatar
Nick, nice work on this, but I have a question about the oil fill and pcv provisions. I'm assuming you had to get an intake that had the oil filler tube on it, was it new or used? Also , what about pcv?
Thanks, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 02-17-2024, 12:28 PM   #93
nicklear36
nicklear36's Avatar
Thanks, Rg
I had my engine builder drill a hole for a baffled PCV grommet in the back of my Edelbrock intake. The intake is the one with the front oil fill option. Here's a pre-made version that has some good pics:
https://paceperformance.com/i-514637...e-drilled.html
Old 02-17-2024, 02:01 PM   #94
raggedjim
raggedjim's Avatar
Thanks! Rg
Roger
'70 GMC Jimmy 2wd
Old 02-26-2024, 08:55 AM   #95
PowerdbyChevy79
PowerdbyChevy79's Avatar
Getting there
That looks damn good!!
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 03-13-2024, 02:20 PM   #96
nicklear36
nicklear36's Avatar
Some progress pics.
Shortbed chop is underway, dents have been pulled, and all cab rust has been cut out. Lots of dirty work and time with the death wheel! I found a pretty knarly sideswipe on the driver side bed panel that took lots of pulling.
Thanks to metaloxfab for the video on Youtube showing how to properly cut the bedsides. I also wanted to add the true shortbed wheel well tip in front of the rear wheels so I spent the extra money to get those patch pieces from LMC.
Old 03-20-2024, 12:35 AM   #97
loudchevy
Active Member
loudchevy's Avatar
I haven't had this pop up on my YT algorithm yet, good video. Thx!
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 03-20-2024, 06:58 AM   #98
hewittca
hewittca's Avatar
Nice touch on the wheel well corner. Most people miss that and it always stands out to me. I've always wondered why GM made that change between long and short beds.
Old 04-23-2024, 01:27 PM   #99
nicklear36
nicklear36's Avatar
Sectioned the rear wheel wells to be able to raise the bed floor 10.5 inches. This was not easy by any means but I'm going for a stock look on the entire truck so this was a must.
Old 04-23-2024, 02:06 PM   #100
Kronald_70GMC
Kronald_70GMC's Avatar
Nice work. It looks good!
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
