12-31-2023, 04:48 PM | #1 |
Blue 67
Can you identify there light inserts?!
Hi:
I picked up these fenders for $25 each since mine where totally damaged. The seller didn't know what kind of light insert these are since they were rivet in a piece of sheet metal! I like to know what lights may go in there just in case I like them and I want to keep them this way rather than patch them. Thanks and happy new year.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
12-31-2023, 05:10 PM | #2 |
Re: Can you identify there light inserts?!
On a visual search alot of ford stuff was showing up.
I am going to resize and then check it again. It would not let me do it in my photo gallery.
12-31-2023, 08:13 PM | #3 |
Blue 67
That is cool you can do that.
12-31-2023, 08:20 PM | #4 |
I have not found any matches. If you click on the square in the Upper right corner, (Visual Search) Maybe your search will be different .
01-01-2024, 11:37 AM | #5 |
a little more info, like dimensions, may help. have you looked at the possibility that it may simply be a 6" oval stop turn tail light from a grote industries? the ones that mount into a rubber grommet and have a plug in pigtail, they are a sealed unit. then possibly the other holes were used to mount a stainless sheet metal trim part to dress up the area a bit. there are solid backed rubber grommets that would seal out the stuff that flys off the back wheel. anyway, maybe google the product for a quick dimension check of the hole size you have. lots of this style of light were/are being used on home built vehicles and trailers, there are stainless or chrome dress up parts for them as well.
01-01-2024, 11:44 AM | #6 |
mount with dimensions for the hole required
https://www.easternmarine.com/grote-...s-flange-43723 light that fits into the mount https://www.easternmarine.com/grote-...ail-lamp-53962 |
01-01-2024, 11:45 AM | #7 |
another light option that also fits
https://www.amazon.com/Grote-54702-L.../dp/B00Q2FY9Z4 |
01-01-2024, 03:32 PM | #8 |
I'm thinking that that is a light off a later model truck. Could be car but I bet truck
01-01-2024, 03:47 PM | #9 |
They may have mounted a light upside down.
01-01-2024, 04:50 PM | #10 |
Blue 67
That is what I was thinking also.
01-01-2024, 11:42 PM | #11 |
Flipped to see what it looks like. I'd try a 73/80 something Chevy fleetside taillight just to see if it fit.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 01-01-2024 at 11:48 PM. |
01-01-2024, 11:44 PM | #12 |
the first light I thought of was the 70's chevy truck fleetside box tail light
01-02-2024, 12:31 AM | #13 |
70s fleetside might be it. Maybe just the lens over top of the oval light like mr48chev suggested.
It sort of fits, allowing for paralax of original image |
01-02-2024, 12:32 AM | #14 |
I did not check dimensions, just scaled an image of the lens to same size as opening
01-02-2024, 01:09 AM | #15 |
I'd say you can scratch that one off the list.
01-02-2024, 10:37 AM | #16 |
just a thought but with that curve, what about van taillights?
01-02-2024, 10:54 AM | #17 |
Blue 67
I'll see if I can hit the local junkyards to see what might be available. Thanks for the info.
01-02-2024, 11:05 PM | #18 |
You might want to wrap a sheet of card stock aka old file folder around the light opening and trace it out and trim it so you have a pattern you can lay over potential lights. I'd be looking at mid 70's to around 90 as that kind of thing was a hot lick in the 70's, 80's and early 90's.
01-03-2024, 01:13 AM | #19 |
Blue 67
Okay, it is not 80-90s taillight. The curvature does not look the same. 1980s taillight has equal curve or angle on either sides.
01-03-2024, 01:09 PM | #20 |
Maybe contact this guy and he can identify the opening and what would fit: https://www.taillightking.com/index.htm
