Old 01-06-2024, 04:31 PM   #1
Chad22873
Chad22873's Avatar
1970 Blazer Brake Question
Well its been several years but I am back. I started my frame off in 2016 and got about 80% complete and then quit for a few years. Got back to it last fall and am now about 95% done. The only real problem I have now is brakes. I dont have any. Everything in the brake system is brand new. Here is what I have done so far...Bench bled the master, then vacuum bled the system at each wheel about 5 times. Pedal still goes to the floor. Power bled the system twice. Pedal still goes to the floor. Replaced the new master cylinder with another new one. Of course, bench bled it first. Then power bled the system, 4 times and pedal still goes to the floor. I get no air at any of the wheels. My rear brake pads are adjusted correctly. When I push the pedal, all 4 wheels do engage but not tight enough to have brakes and pedal still goes to the floor. I have done this my whole life and I just cant seem to figure it out. I thought maybe you guys might have some ideas. Its a simple system but I cant make it work.
BR549
Chad22873 is offline   Reply With Quote
Old 01-07-2024, 08:34 AM   #2
1970cstblazer
1970cstblazer's Avatar
Question Re: 1970 Blazer Brake Question
Are you using DOT 3/DOT 4 or DOT 5 fluid?
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 01-07-2024, 10:28 AM   #3
72ironmike
72ironmike's Avatar
I apologize in advance because this probably isn't much help. Is linkage from brake pedal to master engaging ? Does the pedal pump up from floor when you bleed brakes ? You say you get no air but do you get a steady stream of fluid from the wheel cylinders ? You know it is gonna be something simple ! You have done way to much work for it not to be.
72ironmike is offline   Reply With Quote
Old 01-07-2024, 12:32 PM   #4
Chad22873
Chad22873's Avatar
Dot3
BR549
Old 01-07-2024, 12:36 PM   #5
Chad22873
Chad22873's Avatar
The pedal comes back up. The brakes engage at all 4 wheels when the pedal is pushed down. They just dont engage tightly enough to stop. I do get a steady stream of fluid at all 4 wheels. The last time I bled them yesterday I actually put a gallon of brake fluid in the power bleeder and let each wheel run until it filled up a 16 oz cup. No air the whole time it ran at any wheel.
BR549
Old 01-07-2024, 12:51 PM   #6
Getter-Done
Getter-Done's Avatar
Do you still have the Original master cylinder for comparison?
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 01-07-2024, 01:01 PM   #7
notsolo
notsolo's Avatar
Did 70 have Brake booster? Rod length between master and booster could be too short. Prop valve?
notsolo is offline   Reply With Quote
Old 01-07-2024, 01:08 PM   #8
72ironmike
72ironmike's Avatar
It sounds like this is all it could be.
Old 01-07-2024, 01:10 PM   #9
Chad22873
Chad22873's Avatar
Unfortunately no.
BR549
Old 01-07-2024, 01:11 PM   #10
Chad22873
Chad22873's Avatar
It did have a booster on it when I got it and I replaced it with a new one. Perhaps the original did not and if I am buying an original master maybe thats an issue.
BR549
Old 01-07-2024, 01:13 PM   #11
Chad22873
Chad22873's Avatar
It does have a prop valve which is also new. I have rolled that around in my head many times but cant seem to think of a scenario where it would be the problem.
BR549
Old 01-07-2024, 01:35 PM   #12
Chad22873
Chad22873's Avatar
So even if the rod is touching the master when I bolt the master up, you guys think that perhaps the rod isnt long enough to complete a full stroke?
If so, does anyone have any idea how long the rod should be?
BR549
Old 01-07-2024, 02:09 PM   #13
notsolo
notsolo's Avatar
If the rod is seated in the booster and in contact with the dimple in the master cylinder, that's not it. Replacement booster rod same length to the pedal as original?
Old 01-07-2024, 02:34 PM   #14
Chad22873
Chad22873's Avatar
Really dont know since I replaced all of that about 5 years ago now. Got it up and running and ready to drive in the last month. Only thing left is the back seat. So I went to drive it and couldnt get brakes to work. Thats when I put the second new master on and still same problems. I will pull the master back in a few min and check the rod. If the rod looks good then I may try the power bleed one more time. Although I have my doubts about the rod. The pedal is at the top and feels like its engaging the master as soon as you press on it.
BR549
Old 01-07-2024, 02:38 PM   #15
hemi43
hemi43's Avatar
Disconnect the lines at the master and plug them. This will determine if your linkage and master is working or not. If you get a stiff pedal, then you'll know the issue is with air traped in the lines or brake cylinders.
Using DOT 3/4/5 makes no difference
You didn't specify if you have front disc or drums.
What is the bore size of the master?
On some masters, you can look down inside the bowls see the pistons move if you look carefully into the small orifices.
Another thing you can try is have someone push lightly on the pedal while you look at the brake fluid in the master. You should see the fluid move a bit when the pedal is first applied because the piston will push a bit of brake fluid back into the reservoir before you get pressure build up. It does this because of the small orifice I mentioned above.
hemi43 is offline   Reply With Quote
Old 01-07-2024, 05:05 PM   #16
Chad22873
Chad22873's Avatar
Well I pulled the master back and what do you know...the push rod was not long enough. An inch short. Honestly I am surprised that I missed that. Evidently, when I replaced everything I just never thought to look. I had adjusted everything up nicely on the other side of the booster but never looked at the push rod on the other side. I made a make shift rod and stuck in there just to see if it that fixed the problem and it did. Thanks to all for replying. Guess I need to order and adjustable push rod.
BR549
Old 01-07-2024, 06:16 PM   #17
notsolo
notsolo's Avatar
Look under the bench thats where everything I want ends up, I think it should be about 2 inches long. Glad you found the problem.
Old 01-07-2024, 07:41 PM   #18
72ironmike
72ironmike's Avatar
Awesome !!!
Old 01-08-2024, 08:37 AM   #19
1970cstblazer
Thumbs down Re: 1970 Blazer Brake Question
BULL!
DOT 5 is a ***** to get microscopic air bubbles out of. I had a heck of a time bleeding a system on a friends 1973 Trans Am. We could not get a very good pedal feel, and eventually flushed the system, replaced all of the rubber and went with DOT4. Problem solved....
Old 01-09-2024, 10:10 AM   #20
hemi43
hemi43's Avatar
BULL!
As far as the problem the OP had, I said DOT 3/4/5 would make no difference and I stand by that statement.
The main difference between DOT 3 and 4 is the boiling point.
Dot 5 is silicone brake fluid and should NEVER be used for daily driven street vehicles, but I guess you learned the hard way and figured that out.
