Old 01-23-2024, 11:34 PM   #1
60short
60short's Avatar
Help me decipher my parts truck (rear gear ratio - Dana 44)
Hey All,
I bought a 1978 GMC C15 High Sierra, that somebody had started pulling apart as a way to help get my 1960 back on the road.
We have gotten down to the basics - I have the engine and subframe, as well as the rear end, but its current stored somewhere I can't get at it, and I am trying to do the math on gear ratios to help me finalize transmission point
All I have with me at the moment is a slightly fuzzy picture of the sticker with codes ....
The truck had leafs and what I believe was a Dana 44
With these option codes, can anybody help me sort the rear gear ratio from here?
A28
DG4
F44
L59
N33
T44
XLB
YF5
ZLB
ZY4
64W
A01
C60
B63
K30
MX1
N41
U35
XLB
YLB
ZQ2
Z62
68L
Thanks!
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is offline   Reply With Quote
Old 01-24-2024, 01:12 AM   #2
roboticjunky
Re: Help me decipher my parts truck (rear gear ratio - Dana 44)
None of those rpo codes are for the axle ratio. For the axle it would be Gxx or Hxx. Here's a listing of axle rpo codes.
https://www.differentials.com/gm-axl...ication-codes/
roboticjunky is offline   Reply With Quote
Old 01-24-2024, 02:00 AM   #3
kwmech
A 1978 is not going to have a dana 44 rear axle. Most likely a 10 or 12 bolt. Post a pic of the rear diff cover. Pull the cover anyways to get numbers off the ring gear, do an inspection and change the fluid
kwmech is online now   Reply With Quote
Old 01-24-2024, 09:19 AM   #4
Keith Seymore
Keith Seymore's Avatar
This is correct.
Additionally, if the truck has the base ratio it will not appear on the SPID or will show "GQ8 - Base ratio". If the person who ordered the truck had chosen an optional ratio then those typically do appear on the SPID with the corresponding RPO.
Per the powertrain chart in the generic info packet the base ratio for a '78 C10 with L59 and federal emissions is a 3.07 (HE3).
https://www.gm.com/content/dam/compa...olet-Truck.pdf
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-24-2024, 09:20 AM   #5
Keith Seymore
This is also true.
Probably your best bet since there are no guarantees the original ring and pinion are still in place after 45 years.
K
1979-1986
1986 - 2019
Old 01-24-2024, 09:06 PM   #6
60short
60short's Avatar
does the fact that is a GMC (C15) vs a chevy (C10) make any difference
I am hoping to be where the truck is tomorrow, so I will take some better pictures, but here is what I have at the moment
Thanks for all of the responses so far!
Old 01-24-2024, 11:05 PM   #7
Keith Seymore
Nope.
C10 vs C15 = marketing magic
K
1979-1986
1986 - 2019
Old 01-25-2024, 12:39 AM   #8
60short
60short's Avatar
Originally Posted by Keith Seymore View Post
Nope.
K
Kind of what I figured, but I could't find anything concrete on the option lists for GMC vs Chevy - I will try and grab some pictures, or crack the diff open and count the ratio anyways - appreciate your help!
- another Keith
Old 01-25-2024, 08:46 AM   #9
Keith Seymore
They are the same.
A GMC is a Chevy with option Z88 "Nameplate conversion" added.
(or - depending on your perspective - a Chevy is a GMC with option X88 added).
All the rest of the options add and subtract in the same way regardless of brand.
K
1979-1986
1986 - 2019
Old 01-27-2024, 07:03 PM   #10
60short
60short's Avatar
ok, so I am seeing 14:43 = 3.07s open diff, is it just a "12 bolt" ?
Old 01-28-2024, 01:41 AM   #11
kwmech
Yes it is, nothing wrong with it. They are a good axle
Old 02-02-2024, 11:45 PM   #12
60short
60short's Avatar
Cool, thank you for confirming - it just helps me make sure I am ordering the right parts (trying to minimize time spent on the lift (re)ordering parts)
dana, ratio, rear
