#3626 | |
Re: PO has me PO'd
Do you know how to fly it?
#3627 |
Re: PO has me PO'd
![]() Smallest ones i can find, for the underside of the wheel arch
#3628 |
Re: PO has me PO'd
That seems to work but I will try to get better drive heads as the hex drive seems to be a little big maybe a pan head since these sealing washers come off
#3629 |
Re: PO has me PO'd
1/4 round lines up nicely, needs a little help
#3630 |
Re: PO has me PO'd
The heads of the screws are to large for trim to sit flush, I'll have to get flater ones
But the trim does fit correctly on the arch ![]()
#3631 |
Re: PO has me PO'd
I may have to rethink this, as it takes quite the amount of pressure to close this gap at the top of repair panel
#3632 |
![]() Join Date: Aug 2007
Re: PO has me PO'd
Hey Jim, How are you planning to fasten the patch piece to the side panel? I used the step tool and panel adhesive on my doors, no warping from welding.
7D2N
Just for the fun of it |
#3633 |
Re: PO has me PO'd
These
![]() 2-56 smallest ones i think I can work with... I was going to flange and body adhesive, but 2 things popped up, there's a slight curve in the 1/4 panel and not sure if it would warp the panel Plus the cost of the applicanter gun was 100.00 Thanks for stopping by, your truck is looking amazing, nice work,impressive work on the vent window, mine are still in 3 pieces
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-11-2024 at 09:14 AM. |
#3634 |
Re: PO has me PO'd
![]() T-8 bought from McMaster Carr part # 92750A054
#3635 |
![]() Join Date: Mar 2011
Re: PO has me PO'd
Jim I have access to one of those guns if ever needed my cousin retired body guy
Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#3636 |
Re: PO has me PO'd
Seems to be less burrs than the Dremal
#3637 |
Re: PO has me PO'd
OE trim seems to fit wheel arch pretty well
Clamp in place, see if it will bend to contour ![]()
#3638 |
Re: PO has me PO'd
Finally found the right tool to cut an arc in the sheet metal precisely
#3639 |
Re: PO has me PO'd
#3640 |
Re: PO has me PO'd
Reinstalled the American billet bezels flipped them backwards to see how they fit
Marquez did not fit have to machine about 50 thousand off, plus American billet was 1/3 the price ![]() Just to chunky to install as designed, I'll see if I can install the rectangular trim
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-10-2024 at 10:42 AM. |
#3641 |
Re: PO has me PO'd
#3642 |
Re: PO has me PO'd
[quote=jaros44sr;9294648]Reinstalled the American billet bezels flipped them backwards to see how they fit
Marquez did not fit have to machine about 50 thousand off, plus American billet was 1/3 the price ![]() Just to chunky to install as designed, I'll see if I can install the rectangular trim[/quote] Jim I like.....Im going to have to have a set of those for my 69 build can you send me the info on AMERICAN BILLET thanks Jess
#3643 | |
Re: PO has me PO'd
Your step side is looking great, Almost ready to drive?
#3644 |
Re: PO has me PO'd
#3645 |
Re: PO has me PO'd
Thanks for help
#3646 |
Re: PO has me PO'd
thanks Jim small punch list now ....I am driving ....Im coming by for a visit when the weather gets better ...and your available
#3647 |
Re: PO has me PO'd
#3648 | |
Re: PO has me PO'd
#3649 |
Re: PO has me PO'd
Thanks Jim
I do I’ll make sure I’ll call ahead
#3650 |
Re: PO has me PO'd
Seems to be working out
