Heater Delete Plate For Dashboard ?
A fellow member that once produced the delete pieces for under the hood was also going to make one for the dashboard, did he ever offer them ? I emailed him but didn’t hear back ?
71 C-20 07 Magnum RT AWD |
#2 | |
Re: Heater Delete Plate For Dashboard ?
Went down the rabbit hole on this...there were factory delete plates..but rare indeed. Here's one that appears to be rather crude: https://www.a2metalfab.com/products/...l-delete-panel Ebay has heater control rebuild kits that you could maybe use to build your own: https://www.ebay.com/itm/15407149443...Bk9SR9yhx8a0Yw There's one factory radio delete panel on eBay, but it's gonna be smaller than the heater control panel. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Thanks so much for the link !
![]() ![]() Join Date: Jul 2002
On an early truck, I used the opening from the heater controls and mounted a DIN style radio/stereo unit. I then used a radio delete and mounted my 3 round knobs for the Vintage air controls. I can't find the pictures on this computer. I do remember that I welded two metal tabs on each side of the opening as the heater is slightly wider than a DIN hole.
Found a couple pictures.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 02-14-2024 at 08:09 AM. |
landarts
![]() Join Date: May 2005
I am using a standard radio delete plate in that location. Moving controls for custom AC/Heater install into the panel below I made from an extra glove box. Panel will have ac/heater controls, two air vents, and LED rocker switches for 4x4 lighting.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
![]() Join Date: Jun 2002
Nice work on the new gauge panel. The radio delete fits surprisingly well. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
![]() Join Date: Jun 2005
WOW!!!! I love that idea! Nice work!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#8 | |
landarts
I did not want to cut up the dash so this was a way to make it look almost factory using the bottom of a glove box lid. This allows someone to put it back to the stock if they wish. The vents are from an Old Air Products Ac install I am doing. Here is a picture of the start of the panel.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer Last edited by landarts; 02-14-2024 at 10:01 AM. |
So, what does the bigfoot button do???
I used a 1/2” piece of aluminum to make a filler panel.
I then used it inside of the stock heater control panel, and then decided to put the Dakota Digital control panel in it, along with my electric fuel, and fan bypass switches.
"If it ain't broken, fix it 'till it is!" |
![]() Join Date: Nov 2015
X2 on the radio delete plate as a heater delete plate
Check out the factory run/sag in the paint on the ashtray
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
You guys sure have the touch when it comes to fabrication ! Congratulations to you all !
![]() Join Date: Oct 2020
Where did you get the illuminated on/off switches? I like those!
You’re looking for the proverbial “Unicorn, with a Golden Horn,, and Mermaid on its back”.
They exist, but I’d venture to say that the Heater Control delete Plate is the rarest of rare options/parts. To my knowledge, they only went in a few fleet trucks, destined for tropical markets. |
#15 | |
I’m sure they can be found on Amazon as well.
#16 | |
#17 | |
landarts
https://www.amazon.com/gp/aw/d/B07HG...b_b_asin_title
