Old 02-16-2024, 09:46 AM   #1
1969stepside
1969stepside's Avatar
seat track restoration
can i restore and repaint my seat tracks for my truck seats? i have heard that you cant paint them cause it will mess them up or something. any tips or tricks to it. i dont want to put some nasty looking seat traks in my truck. they are factory truck bucket seat tracks.
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 02-16-2024, 10:23 AM   #2
dagnabbitt
dagnabbitt's Avatar
Re: seat track restoration
I think pretty much everyone restores and paints them. I soaked mine in mineral spirits over night, blasted them with hot water, then flashdried them with compressed air. Steel wool and sandpaper to get the surface rust off, then Rustoleom.
Just use one coat of paint and lubricate (minimally) with white lithium or graphite grease.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 02-16-2024, 12:48 PM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Imo, a great way to go is professionally blast and Cerakote, probably cold processed. Its not thick and does really great for moving parts, lubricants, and it's especially durable. All my hinges were done this way.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-16-2024, 01:05 PM   #4
1969stepside
i think i will restore them cause everything else on the inside will be done so i dont want them to be an eye sore
Members i Have met
Earl Slick68
Old 02-16-2024, 03:04 PM   #5
dmjlambert
dmjlambert's Avatar
Be careful when working with them, metal sliding thingies that are spring loaded can be hazardous for your fingers.
Old 02-16-2024, 08:15 PM   #6
howzzzit
howzzzit's Avatar
Clean, paint, and use them. Not rocket science and if anyone sticks their head under there and says something crack their noggin.
howzzzit is offline   Reply With Quote
Old 02-16-2024, 08:31 PM   #7
TKCR
TKCR's Avatar
You sure can. I used to restore the bench seats, and I restored all the tracks.
I had a rectangular plastic flower container. One that was long enough and deep enough for the tracks to be fully submerged in EvapoRust. They would soak overnight. Then I would take them to the sink, and with a toothbrush I would rinse them off. Then immediately blow them completely dry with an air nozzle with the air compressor. Paint with VHT Epoxy. After the pint fully dried, then sprayed gel WD40 on all the bearings, rollers and springs.
Old 02-16-2024, 08:38 PM   #8
TKCR
TKCR's Avatar
A few more before and after. Last 3 pics are a 68 GTO tracks. These were totally siezed up. Couldn’t even get them to budge hitting them with a mallet. Once I was done with them they were sliding like new again.
See video https://youtu.be/o_IUEndYxuE?si=Ny5U_2FXyG8bV3r9
Old 02-16-2024, 11:16 PM   #9
71CHEVYSHORTBED402
Of a complete restoration, I was lucky enough my door latches and bench seat tracks didn't need anything more than clean and lubricate. Initially thought about refinishing them, much later determined why would I. And what howzzzit said
Image before restoration. A northern Nv. garage is real kind to these vehicles.
Tony
Old 02-17-2024, 10:52 AM   #10
un4gvn!
un4gvn!'s Avatar
I used Birchwood Casey gun blueing on my seat frames and their holding up pretty good.
un4gvn! is offline   Reply With Quote
Old 02-19-2024, 08:58 AM   #11
1969stepside
this is some awesome information
Members i Have met
Earl Slick68
