02-20-2024, 01:11 PM | #51 |
Active Member
Re: Steering wheel choices
02-20-2024, 04:19 PM | #52 |
Yes. If it's not too rotted away. You begin by sanding it down all around. Then where there are deep cracks on the spokes, and in the rim, you make deep grooves with a triangular file. When you've found and grooved all the cracks, you fill each one with a two part filler epoxy. JB Weld is one brand. Make the patch bigger than the groove or pit filled in. After it's hardened -- you file and sand the wheel back to original shape.
To Paint: You shoot it with a pre wash like PRE. When dry shoot a few coats of primer. Sand down any flaws. Reshoot primer. Shoot your preferred interior color. Seal it with clearcoat. The '67-'68 wheels are made from what they called Composition. It was a paste of various nutshells and glue. Its natural color is kind of a putty/neutral.[ It was also used in 1st generation skateboard wheels -- before silicone.]They all were painted. '69 - '72 Wheels were cast in Cycolac -- a very hard plastic. Also used in bowling balls. The plastic came in the individual colors GM ordered. People have restored the Cycolac wheels using the same method as Composition, but a few have not had best results. I'd be interested in hearing how '69-Later Wheel Restorers have fared.
02-20-2024, 07:42 PM | #53 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-20-2024, 08:41 PM | #54 | |
Not impossible to carve in grain on a JB Weld surface if you're an Art School type, but so few of them are also mechanics.
