Seat bolt size and thread pitch?
I dont have seat bolts for my truck. What size is the bolt and what thread is it? Also is it a standard bolt or is it special? any pics of them?
Under Construction
Re: Seat bolt size and thread pitch?
they look similar to the cowl bolts. I believe its the same size as well. Pull a bolt from the side of the windshield cowl and see if it matches
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
5/16 coarse thread
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Under Construction
i believe 3/4. dont have any infront of me at the moment. the 1" will work as well as there are no stops etc. to keep from sinching down.
The Red Menace
I bought new bolts for my seat from LMC and they worked perfectly.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
![]() Join Date: Nov 2007
I pulled two and they were 5/16" at the threads, 3/4" long, but I dont have a pitch gauge...
72 C20 Longbed 05 1500 Z71 |
are the bolts for the bucket seats the same as the bench seat bolts?
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
![]() Join Date: Feb 2009
If you mean the bench seat brackets to seat and floor, (GR 5) 1/2" hex recessed head tapered bolts with spin washers. The bolt threads are 5/16-18 x 7/8" under the spin washer, and the heads are stamped RBM.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Who Changed This?
![]() Join Date: Jan 2013
^ What is a "spin washer"?
Here's a whole bunch of them before refinish. Integrated. You know, the washer that spins around under head but won't pull off. Most are flat washers, some star washers, some split washers. Tooth washers for headlight grounds.
Basically my bench seat bolts are 1" long under head, but 7/8" - ish under the spin flat washer. According to my truck, similar bolts are often 3/4" under the spin washers. Those for my bench seat a pinch longer.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-21-2024 at 12:25 AM. |
so the bench seat bolts and bucket seat bolts are diffrent? i am asking about the bolts that hold the seat track to the cab floor
Just my two cents. GM would have gone out of their way to simplify stuff, so to me that means seats take the same bolts. But I can only speak for a bench. Another way to think about it, I don't have a bracket in front of me to measure, but I don't know, 3/16"ish? Full 1/8" at least, guessing. If the brackets you're working with are the same, yeah, probably the bolts cited above. Note GM had their reasons for installing grade 5 seat bolts.
#15 |
Aren’t the original style bolts pointed to assist in getting them started compared with a regular bolt.
71 C-20 07 Magnum RT AWD |
#16 |
do you need to use grade 5 bolts or grade 8 bolts?
