02-18-2024, 03:12 PM | #26 | |
Re: Getting brake lights to work
Have you checked both sides of the T/S plug for correct wire position?? What were the results when you removed all those LEDs and put the incandescent bulbs back in??? Have you checked to see if some random wire is erroneously connected to something else, or not connected at all?? The clue to this is the brake lights being on with the ignition switch and headlight switch being ON... These 2 circuits are 2 entirely separate and different circuits, NOTHING is shared... NOTHING connected to the headlight switch is also connected to the brake lights nor turn signal lights. |
02-18-2024, 03:15 PM | #27 |
With headlights off brake lights and turn signals work like normal, when im driving and turn the headlights on turn signals still work but the rear lights go on like the brakes are fully engaged.
02-18-2024, 03:23 PM | #28 | |
Im working to trace out the wiring currently for the dash wires to see if there is a wire landed in the wrong place on the digital Dakota box or harness. Americanautowire has their wiring diagram broken down or in a full harness view https://americanautowire.com/collect...y-truck-510347 https://api.americanautowire.com/sho...20IN%201.0.pdf |
02-18-2024, 04:51 PM | #29 | |
On the other hand, if you're working on a '73 - up, you might get more and better responses if you get an administrator to move your portion of this thread to a more appropriate forum... |
02-25-2024, 04:42 PM | #30 |
New Member
OP, my curiosity is sparked by two interesting things you note:
1: turning on the headlights causes the problem 2: disconnecting the turn signal makes the problem go away My '69 had an issue where: 1: when I turned my headlights on, the turn signal INDICATOR in the dash came on inappropriately. 2: If I disconnected the turn signal, this problem went away. I regrounded the turn signal and this problem went away. It made me think that somehow, with power going through the headlight, that current was somehow finding ground through the switch or something, through a path that went through the indicator lamps and activated them... or maybe that explanation could be way off , but anyway I wonder if whatever the true explanation is, maybe something similar is happening for you, and the problem might go away if you improve the ground to your turn signals. It'd be easy enough to test. Run a jump wire from your turn signal lamp assembly to ground, and see if the problem goes away! |
02-27-2024, 11:45 PM | #31 |
subd ....good info here I too am having some rear signal and brake light issues
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
