Old 02-25-2024, 02:59 PM   #1
Ziegelsteinfaust
Flat tappet lifters
I recently decided I am going to keep the big block in my Plan D truck. A week ago I scored a edelbrock intake, good heads, and a old Crane 272 cam.
The lifters were not stored in a way to be able to reuse.
So obviously Crane is no longer around.
Which brands of lifters are considered the best now?
Are Rhoads lifters worth over double the price vs Comp cams?
Ziegelsteinfaust is offline   Reply With Quote
Old 02-25-2024, 06:31 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Flat tappet lifters
If you are interested in longevity of the cam / lifters project, I would recommend you buy a complete Cam and Lifters set, all new.
The reasons are as follows:
The "old Crane 272 cam" is an unknown item with respect to wear and tear run in and general condition.
You have to wonder why lifters were not included? Did they fail? Run dry? poor break in? etc.
If the supplied cam has been run, has it lost the offset angle ground into each lobe to ensure the lifters spin correctly?
Remember, its not only the cam/lifters you need to replace if something goes wrong, you also have gaskets, materials, oil and filter, plus other items.
If the cam chews up the new lifters, the metal dust will go everywhere inside the engine.
Just my 2 cents worth....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 02-25-2024, 11:35 PM   #3
Ziegelsteinfaust
He upgraded everything in one swoop. So these are left over parts. Like I said the lifters were not stored in a way to reuse. They were not organized so i cant use them. Lifters mate to the cam, and can not be switched. Yet i can use new lifters.The cam is fine. I have a budget I need to stick too, and I am looking at areas to cut corners.
Old 02-26-2024, 12:20 AM   #4
Stanco
Stanco's Avatar
Flat tappet lifters have been failing at an alarming rate for the last several years.
Installing new lifters on a used camshaft in a different block will have very poor odds of success.
Stanco is offline   Reply With Quote
Old 02-26-2024, 03:06 AM   #5
Ziegelsteinfaust
3 cam companies say it is fine as long as the cam is good.
Old 02-27-2024, 10:22 AM   #6
THI
Active Member
THI's Avatar
On flat cams I will use only GM lifters, they have a hardened disc on the bottom of the lifter rather than case hardening the lifter body. Have broken in 4 engines in the last three years with these lifters and have had no issues (cams were older new cams still in their box). I am going to roller cams in the future due to poor cam cores available today.
THI is offline   Reply With Quote
Old 02-27-2024, 03:01 PM   #7
cadillac_al
One of the cam companies makes "cam saver" lifters that supposedly flow more oil to the cam. I am considering trying them next time I buy a cam.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-27-2024, 05:51 PM   #8
weq92f
weq92f's Avatar
My experience...comp bad...howards good.
YMMV
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-29-2024, 03:27 AM   #9
Ziegelsteinfaust
I want to go roller so bad., but the cost kills it. It would cost me almost $2500 due to the parts, and head work.
I need .990 lifters so GMs are to small
Old 02-29-2024, 03:33 AM   #10
Ziegelsteinfaust
Just looked those up, and they sound like a good option to keep the cam alive
Old 03-12-2024, 09:02 PM   #11
hjewell2
hjewell2's Avatar
Originally Posted by thi View Post
on flat cams i will use only gm lifters, they have a hardened disc on the bottom of the lifter rather than case hardening the lifter body. Have broken in 4 engines in the last three years with these lifters and have had no issues (cams were older new cams still in their box). I am going to roller cams in the future due to poor cam cores available today.
bingo!!
hjewell2 is offline   Reply With Quote
Old 03-12-2024, 10:18 PM   #12
Stepside Jim
I read the GM lifter suggestion from THI, I've been messing with a different brand lifters trying to solve a ticking noise for some time now.
I found the GM ones at Summit, ordered and installed.
My GM lifters said they were still made in USA.
I've got about 100 miles on them now, all is quiet.
Thanks for the suggestion THI.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline   Reply With Quote
Old 03-14-2024, 09:08 PM   #13
Myself
This is COMPLETE and utter bs that keeps getting repeated through the years. I'd scuff the bottoms with some 400 grit wet paper, clean, and install. Much better bet than trying any new flat tappets. I've personally done it this way several times and I have buddies into dirt tracking and truck pulling that have re-used UNsorted lifters more times than we could possibly even talk about. I might as well go pick all my batteries up off the concrete shop floor before they're ruined while I'm at it .
Myself is offline   Reply With Quote
Old 03-15-2024, 08:09 PM   #14
cadillac_al
I believe Myself. The patterns can't really be that different
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 03-23-2024, 05:12 PM   #15
burnin oil
If it is a solid lifter look for some with EDM oil holes on the face. They put oil on the cam lobe as it runs.
burnin oil is offline   Reply With Quote
