Old 03-01-2024, 11:22 AM   #1
72c20customcamper
72c20customcamper's Avatar
Blueprint motor ?
I just got off the phone with the tech dept . Wanted to know if the stock Ram horn manifolds would bolt up to the heads . Tech said they recommend headers and I do not want to use headers on the truck . Tech said that the Ram horn manifolds may work . So to those who have used these engines did you run into problems with the exhaust manifolds ?
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-01-2024, 11:31 AM   #2
dagnabbitt
dagnabbitt's Avatar
Re: Blueprint motor ?
I put 2.5 inch Corvette manifolds on mine, they work just fine.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 03-01-2024, 11:58 AM   #3
PbFut
Can't answer the port alignment question. I think the best way to verify alignment would be to get hold of a header flange and compare its alignment to the head and then to the ram horn mani.
Why are you avoiding the recomended header?
PbFut is offline   Reply With Quote
Old 03-01-2024, 01:07 PM   #4
72c20customcamper
I have Ram horn manifolds are the corvette different? Larger ports ?
The exhaust ports are raised ports the alignment should be the same . Tech said the factory non rams definitely interfere with the plugs .
I really don’t like headers on fairly stock motors no need for them and there’s always figment issues and the rust fairly quick . I have ceramic headman headers on my Chevelle after 3 or seasons they look like crap .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-01-2024, 02:26 PM   #5
dagnabbitt
dagnabbitt's Avatar
Yes, they are just another half inch. Also, they go straight down instead of angling off at a 45 degree as the stock truck ones do.
I don't like the maintenance that headers require, so when I read somewhere that the 2.5 inch manifolds flow basically the same as headers do, I went with that option. I also have 2.5 inch exhaust. Sounds good.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 03-01-2024, 02:52 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
The 1/2" is larger at the outlet. I had a SHP 327 in my '64 Impala, and every head that was on it fit the manifolds fine. I'd guess that BPE just wants you to run headers. I've never seen that era SBC that required a different exhaust manifold. In fact, I put a 350 Target engine in a '64 Corvette with no manifold issues. That was in '82, so that year engine.
~Steven
Simi Valley, CA
Old 03-01-2024, 02:59 PM   #7
72SB
my 67 327 exhaust manifolds "fit" but #7 & 8 plug was right against the manifold on my BPE. I just put Patriot mid length headers on which fit perfect
Understand BPE makes performance motors (modern AL heads & cam) so typically one wants headers to complement that. BPE motors are new, including block, and come with a warranty. Mine has been trouble and leak free for a few years now.
72SB is offline   Reply With Quote
Old 03-01-2024, 04:57 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
OK, I see why.
~Steven
Simi Valley, CA
Old 03-01-2024, 08:43 PM   #9
mm1077
Active Member
mm1077's Avatar
I just finished installing stock aftermarket manifolds onto my bpe cruiser engine last weekend. I had to do a little massaging with the grinder to clear the valve covers, otherwise they fit well. I don’t have any issues with plugs/wires clearances.
mm1077 is online now   Reply With Quote
Old 03-04-2024, 11:44 AM   #10
72c20customcamper
Thanks for the info . I’m going to use the stock ram horns if I run into a problem then ill do something different
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-04-2024, 12:57 PM   #11
72SB
This style of manifold was on my 327 which did bolt to the BPE heads but 7&8 plug boots were slammed against that manifold. The Ram Horn may work as noted
BPE uses raised port heads, more modern design that gen 1 SBC.
Old 03-04-2024, 09:32 PM   #12
72c20customcamper
My 327 manifolds on the 68 are the same . The engine is going in my 72 with a 350
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-04-2024, 10:40 PM   #13
dmb
Active Member
dmb's Avatar
The older I get the less I think of headers , When I was a kid, I spent half my money on tires and the other half on starter solenoids. lol
Old dogs and children and watermelon wine
dmb is offline   Reply With Quote
Old 03-05-2024, 03:57 PM   #14
custom10nut
custom10nut's Avatar
Yep, same here.
Headers a cheap, but they are hot.
I lost count of the number of starters I’ve replaced.
I could have paid for a set of Ramshorn manifolds three times over.
Ramshorns are on my list of parts in the future
custom10nut is offline   Reply With Quote
Old 03-06-2024, 07:06 PM   #15
72SB
mid length headers are not a starter heat problem.
Ceramic coated headers are considerably cooler than non-coated
gear reduction starters are also smaller and offer considerably more cranking effort. I bought my REMY GR starter on rockauto for around $70, for 153 tooth FW
My BPE motor with mid length headers and starter in my 67 Camaro for refrence
Old 04-12-2024, 12:34 PM   #16
72c20customcamper
The manifolds will clear the plugs just need to grind a little on the casting to clear the valve cover . Looking at the manifold not sure if this is a problem or not the center ports are slightly lower than the front and rear . Can see light with a straight edge . They never leaked in the old motor . I bought these because Blue print emphasizes to use performance gaskets not Stock
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-12-2024, 01:12 PM   #17
PbFut
You may want to look at Remflex gaskets. I used them on the racing LS2 with zero issues. I bought a pair of cheapo Edelbrock heads for the truck SBC. The ports were a little off for the headers I had. It put the flange openings a bit tight to the head port and blew out the standard gaskets within days. I thought of the Remflex I'd used on the LS and have not had an issue since.
Old 04-12-2024, 01:26 PM   #18
72SB
+1 on Remflex. BPE tech actually looked up a few ones that would work with my BPE and manifolds from my 327 it replaced
Old 04-12-2024, 01:44 PM   #19
Steeveedee
Who Changed This?
Steeveedee's Avatar
If you have a long enough stationary belt sander maybe you bring it back close to "Blanchard ground", like factory. I used a flat bastard file to dress some manifolds on an old Buick. Took a lot of time.
~Steven
Simi Valley, CA
Old 04-29-2024, 07:59 PM   #20
72c20customcamper
Well I’m starting to mount the accessories and manifolds . Never had an engine with aluminum heads . Should I use anti seize on the bolts ?
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-29-2024, 08:31 PM   #21
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
yes, on anything that is threading into the aluminum use anti seize for sure.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 04-29-2024, 09:24 PM   #22
Steeveedee
Who Changed This?
Steeveedee's Avatar
In fact, if there is room to install the manifolds with studs, I'd do that.
~Steven
Simi Valley, CA
Old 04-30-2024, 07:21 AM   #23
72c20customcamper
Was my line of thinking but wasn’t sure on the manifild /header bolts
i decided to not use the Ram horn manifolds I ordered Headman stainless steel headers .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
