Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-25-2024, 11:26 AM   #26
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Help clarify harness adaptation existing HEI to OE points
Quick update. Yesterday I dropped in the OEM, rebuilt points distributor from Advanced Distributors. I think it’s clocked appropriately.
The internally regulated coil diameter is slightly larger than an OE example but fits in the OEM bracket although I had to use a #8 bolt and nut to secure it instead of the larger diameter original screw.
If I get time today I’ll run the new plug wires.
Old 02-29-2024, 12:28 AM   #27
dmjlambert
dmjlambert's Avatar
OK, so is it the IC12SB coil that one would use with the resistor and bypass wires?
dmjlambert is online now   Reply With Quote
Old 02-29-2024, 04:56 PM   #28
dmb
Active Member
dmb's Avatar
Originally Posted by dmjlambert View Post
ok, so is it the ic12sb coil that one would use with the resistor and bypass wires?
ic14sb
dmb is offline   Reply With Quote
Old 02-29-2024, 08:42 PM   #29
dmjlambert
dmjlambert's Avatar
Well I think that is the one we just discussed using without resistor wire and without bypass wire.
Old 03-03-2024, 08:40 PM   #30
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Adjusted the timing to 18 btdc and went on a brief drive. Idles smoother than ever and there’s no hesitation. Very pleased at the moment.
Thank you for all the help!
Old 03-04-2024, 08:55 AM   #31
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Help clarify harness adaptation existing HEI to OE points
I had similar results when I switched the Pro Billet MSD distributor out for a correct distributor for my 1972 Cheyenne 402. The truck has a lot more pep and idled smoother.
The few downsides to points are the occasional rubbing block and contact wear. For as little as mine are driven, it will be years before they need a tune up. Using USA made old issue parts does make a difference, and also using the proper distributor cam lube.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 03-04-2024, 09:59 AM   #32
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm with you. For the amount of driving I'll do this is a good way to go in. In fact, I'm tempted to swap out the HEI in the K20 but that hasn't given me any issues. I will send another points distributor off for a rebuild and keep that on the spare parts shelf. Maybe that'll be a project for next winter. The builder made some advance curve and weight adjustments to this one and remarked that it will will perform better than the "truck distributor" GM supplied.
The USA made plug wires from Lectric Limited are a real nice product and are cut to match a 4wd 350 engine HERE. At least right now, it's not difficult to cobble together (nearly) all US made ignition products. There's a guy here in WI selling reproduced copper terminal caps and black D409-style rotors (rotor is in the above photo) both of which are solid. NOS/NORS examples can still be had too. The Echlin NAPA IC14 coil is made in Mexico and I did install it after returning the PRC-made IC14SB. I wasn't able to source a US coil.
