02-21-2024, 11:30 AM | #151 |
Re: The Wrong Bed C10 build
last batch tis time
02-21-2024, 08:02 PM | #152 |
Those wheels look amazing
and of course, great work on the widened 'tubs' and patina, wow
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
02-27-2024, 06:54 PM | #153 |
Not a lot of updates ended up getting it running sounds good? Then I went ahead an did some poppys patina to the bed floor and roof. That stuff really worked well. Finally I got front tires for the mags and they installed the wrong ones thankfully they swapped me out but they are too small
02-27-2024, 06:55 PM | #154 |
My buddy Joey made up some art off the truck, too.
03-04-2024, 06:18 PM | #155 |
Got the right front tires in hand and got the truck up and running there is still a little work to do. There a still a bit to do as it has seems to have an ignition system bug above 3000 rpm so a little more to do but I'm happy with how it sounds.
Video link https://www.youtube.com/watch?v=fbOeaawdcx8 |
03-04-2024, 06:38 PM | #156 |
That thing sounds mean! Good job!
03-04-2024, 09:57 PM | #157 |
Sounds NICE!
03-04-2024, 10:02 PM | #158 |
Man, that sounds gnarly. Very cool.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-05-2024, 12:14 PM | #159 |
Active Member
That sounds great!
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
