Old 10-27-2023, 06:54 PM   #1
TheBLUEHAWK14
HELP keep blowing fuse!
Hey yall so i put a Painless kit on my 1969 c10 and for some reason i hit the brake i keep blowing the fuse for it. Any ideas?
TheBLUEHAWK14 is offline   Reply With Quote
Old 10-28-2023, 05:58 AM   #2
Getter-Done
Getter-Done's Avatar
Re: HELP keep blowing fuse!
Which kit did you install?
That may help if someone used the same kit you have.
Sounds like you have a (Hot) wire going Directly to ground.
I would start with unplugging the rear harness (If it is in sections) and tracing where it is making a direct ground.
Also check for pinched wire/wires where they are run thru the cab and bed.
84 Chevy K-20
Old 10-28-2023, 02:22 PM   #3
cj847
cj847's Avatar
Shouldn't be that hard to track down. The white wire #918 is probably grounding somewhere.
If it only blows when hitting the brake (and does not blow when emergency flash and blinkers) that only leaves a faulty/shorting brake switch as the culprit.
If it blows with flashers and or blinkers I would suspect a problem in the steering column or the blinker switch.
cj847 is offline   Reply With Quote
Old 10-28-2023, 04:41 PM   #4
TheBLUEHAWK14
https://www.painlessperformance.com/wc/10406 this is the kit i got
Old 11-09-2023, 05:35 PM   #5
TheBLUEHAWK14
So have done two turn signal switches and still keeps blowing the fuse
Old 11-09-2023, 07:21 PM   #6
cj847
cj847's Avatar
So, the fuse blows when you use the brake and the turn signal and does not blow when you use the flashers? Need to confirm that the flashers don't blow a fuse as it is a separate circuit. If the flashers blow it, it is more likely in the taillight wiring.
Assuming the above is true, the only things it could be are:
-mis wired or shorted at the steering column multi connector (likely) This is easy to mix up. Check page 84-87 of instructions.
-defective/mis wired brake switch.
-short in the column (not likely since you've tried 2 switches)
-defective blinker switch (not likely since you've already tried 2)
-defective/mis wired dome light switch (that is the only other thing on the circuit).
PS> Do the blinkers work until you hit the brake?
Old 11-09-2023, 07:27 PM   #7
RustyPile
RustyPile's Avatar
Electrons are invisible, making them hard to locate when they go awry. It's easy to locate a coolant leak or brake fluid leak.. They leave a trail of evidence.. Not so those pesky electrons.. Follow this kink to a tool that will guide you directly to the short.
https://www.toolaid.com/product/25100
RustyPile is offline   Reply With Quote
Old 11-10-2023, 06:32 PM   #8
weq92f
weq92f's Avatar
Nice Kink! Never knew such a tool existed...Ya Science!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 11-10-2023, 07:21 PM   #9
Getter-Done
Thanks for posting this.
Reminds me that I have not seen or thought of
the one got one of these I used years ago to fix a melted wire issue.
Now I need to Look in my Electrical cabinet and see if I can find it
84 Chevy K-20
Old 11-14-2023, 04:55 PM   #10
TheBLUEHAWK14
So looked at it so I can plug one of my LED United Pacfica taillights on one side and then a Standard Incidence bulb on the other to get the LED to work but when the switch is engaged for the opiste side with the stanadard bulb it dull flashes.
Old 12-15-2023, 03:42 PM   #11
TheBLUEHAWK14
so got some updates for you guys so I ended up figuring out that I need to ground the tail lights in order for them to work but the problem I'm having right now is my tail lights aren't going on when it pulled the actual headlight on so I need to figure out what's going on there but otherwise I have everything else working at the current time.
Old 12-15-2023, 08:44 PM   #12
Getter-Done
First thought is the head light switch may not match the harness.
Here is a copied Quote from Paul in post#7 and then the link it came from.
{1967-72 Headlight switch, GM used 2 different styles.
1967-68 8-Terminal headlight switch
or a 1969-72 7-terminal headlight switch.
Note- 1967-68 the front park lights go off when headlights turn on using original style switch, if you want the front park lights to stay on with headlights choose the 7 terminal headlight switch as they are interchangeable.
If your using a 69-72 version you should still have functioning lights so there is a good chance you have other issues. Per above you can identify the 67-68 switch by its 8 terminals and the 69-72 by it's 7 terminals.}
Link: https://67-72chevytrucks.com/vboard/...witch+diffence
84 Chevy K-20
Old 03-08-2024, 02:26 PM   #13
TheBLUEHAWK14
Hey so got it so one of the wires on the rear harness got pinched when I ran it through the frame rail!
Old 03-08-2024, 05:46 PM   #14
LNP
My LED tailights require a grounded flasher for the turnsignals and the flashers.
A pinched wire can and will ruin your day
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 03-08-2024, 10:21 PM   #15
Getter-Done
Glad you Found it.
84 Chevy K-20
